Status
Not open for further replies.
1 - 12 of 12 Posts
I am listing this because there is SO much heated debate about what is recommended for use in the Allison 1000 transmission in our trucks. I have come across a brochure that I think will help.
Feel free to discuss, bash, kick, scream, fight and generally cause all kind of hate and discontent about the fact that Torque Drive is not mentioned in the brochure.:rof
I have used it for years, even before actually having an account at all with them. When I found out that I could have their products wholesale I went for the Dealer account because it was only $10 more per year and the account has more than paid for the fluid maintenance on my own vehicles. So the way I see it, for me personally, being a dealer is simply a way for me to have my regular maintenance and the products I use to pay for themselves. You talk about saving money...lol Either way, the brochure is here for everyone to know the facts about the fluids recommended for their Allison 1000 Transmission.
Hope this helps a bit!
God Bless
Chris
Allison 1000 Fluid and Interval Recommendations Brochure
One question on this subject I have is when I change spin on filters. Does it matter if I add Dex IV if there is Dex III in there? I also have leaky transmission lines and until this gets fixed I need to add a little bit.
Slave to the Interwebs
No, the DEX VI is an upgraded fluid that is better than DEXIII so using it will not harm anything.
Dex VI is full synthetic though. Is it ok to mix the two??I am just asking because I do not know.
Also If I had a tranny leak and had to keep adding fluid I would certainly use the DexIII if it was in there to begin with just because of cost. Heck I have used DexIII in power steering pumps that had leaks in them as well.
I just saw you have an 07 with the six speed. It does not have DexIII in it, it is Dex VI you probably do not want to mix the two in a six speed.
I actually found the answer to my own question on another forum:
I'm confused as to what this line in the brochure is telling me:
Effective January 1, 2007, General Motors no longer licenses DEXRON ®-III fluids. DEXRON ®-VI fluids may be used in the 1000 and 2000 Product Families transmissions beginning with S/N 6310670488 and 6320784373
Why does it post two serial numbers? My Serial number fall between the two numbers listed so does that mean I can use Dexron VI in my and still be compliant with manufacturer's recommendations?
Allison has established serial number cut off’s for use of DEX VI (S/N 6310670488 and up for Indianapolis built transmissions, AND... S/N 6320784373 and up for Baltimore built transmissions used in GM pickups.)
It has nothing to do with your transmission falling between the two numbers.
Thanks for clarifying that last part. I just went to go crawl under the truck to find mine was 6321060552, and was a little freaked out because my number didn't fall between the two, and even checked my manual stating DexVI was fine to use. At least now I know I have a Baltimore built tranny...
does the 6 speed allison in my 08 have dexVI in it from the factory
Yes! They started using Dextron VI around 06.
Dex VI isnt a good idea to use in late 06MY and earlier allisons. It hardens/wears out the seals over time. IMHO on MY06 and earlier allisons, either Dex III or any compatible TES-295 fluid (transynd, mobil 1, citgo quatrasyn, amsoil, etc). This is what Mike reccomends...not to speak for him, but he is not a big fan of Dex VI (in the allison).
ben
1 - 12 of 12 Posts
Status
