1 - 8 of 8 Posts
drive 1997 K2500 chevy suburban with the 7.4L(454) big block and the stock 4L80E tranny is starting to go i think and i was curious if anyone knows if i would be able to put an allison into it with out a lot of modification, and if i can what model would be best or easiest, any info would be awesome, thanks
Easiest (and best imo) would be another 4l80e.
You can pick up a low low mileage 4l80e from a junkyard for $600 or so..... an allison is going to cost you in the thousands, and not to mention all the special parts you are going to need.
im goin to guess an 8.1l allison is the one you would need to use but i think it would be alot of work due to the size of an allison and all the electrical that comes with it
Slave to the Interwebs
I am not sure if you can bolt an ally to the backside of the 7.4. I know they offered the ally in the 8.1 gasser version. That would probably be your best option if it is possible as the TCM will be for a gas motor.
For what a 4l80 cost I would just throw in a replacement as the allison is alot more expensive. You can get your 4l80 rebuilt for about 1500
the 4le80 will hold up just as good as the allison will with the 454 and is alot cheeper
Thanks for the info guys after doing a little more research and hearing from other people that i should stick with the 4l80e i am probably just gonna rebuild it, and thanks for that link danhr
I just thought I'd throw in my $.02. An Allison isnt all that its cracked up to be. it has nice gear ratios but that's really one of it's only strong points IMO.
1 - 8 of 8 Posts
