1 - 12 of 12 Posts
So doing a bunch of things tonight on my truck, I plan on changing the Allison spin on filter, this is my first time ever doing the tranny filter.
Can I spin off the old one change n clean the magnet put it on new filter, and toss it back on tranny without losing to much fluid? Or is there a way to plug it it what's everyone doing, or am I going to have to top up the tranny fluid no matter what? I have no transyd at the shop either:(
Thanks guys
IIRC, you lose about a cup full of fluid. Just add the new filter & magnet & wait until the trans temp has reached 160°F - 170°F (72°C - 77°C) then check the fluid level.
at least fill the filter up with trans fluid..then recheck level after the trans gets up to normal opp.temp....thats what ive done and i have not any problems...scott
The magnet will be on top of the filter when you remove it-. Clean it and put it back on the new filter. You can fill the filter before you install it. Then the fluid level will be OK.
Wrap a couple of paper towels around the spin-on as you unscrew it. You'll know why. :D
Hey guys whats the change interval on the trans filter?
spin on=20k
internal not needed till overhaul or 100k some say
I changed the allison spin filter when I did the oil change every 10000.
And buy it from a vendor here or an Allison dealer--not GM dealer ($$$)
Exactly^^^. You can go on Allisons website & to find the nearest Allison dealer in your area. The Spin on filter is $10 from the Allison dealer & from most online stores.
Thanks for the info fellas! I got er done with ease! At 10 bucks you can't go wrong!
1 - 12 of 12 Posts
