1 - 1 of 1 Posts
I want to add a BD Remote Fuel Filter and a single Kennedy Lift Pump. My problem is that I have a Transfer Flow extended capacity fuel tank, which occupies a lot of space. I cannot mount the BD Fuel Filter on the frame, using their mount, in the location they recommend. I will be mounting the Kennedy Lift Pump on the factory bracket adjacent to the tank and directly over the drive shaft. I know the Nicktane setup would work, as it mounts on the outside of the frame, but I really wanted to use the BD. Has anyone else encountered this issue? If so, where did you mount the BD fuel filter? Pics would be very helpful. Thanks.
1 - 1 of 1 Posts
