1 - 1 of 1 Posts
Vendor
AMSOIL Recommended Products For The LLY Model Duramax​
These AMSOIL products are recommended for the LLY model Duramax equipped GM trucks.
ENGINE OIL:
Synthetic 5W-40 Premium Diesel Oil (DEOQT)
Below 0F......5W-40 [1]
Synthetic 15W-40 Diesel and Marine Oil (AMEQT)
Above 0F......15W-40
The LLY requires 10.1 quarts. With any AMSOIL diesel oil listed above, and the use of an Ea Oil filter, the recommended drain interval is 3XOEM (About 22.3k miles) or 1 year whichever comes first.
TRANSMISSIONS:
Automatic Transmission,1000......AF6
Low Viscosity Synthetic ATF (ATLQT)
Torque-Drive Synthetic Transmission Fluid (ATD1G)
Automatic Transmission,6L90......AF6
Below are the transmission fluid capacities:
Automatic Transmission, 6L90 Initial Fill..........6.4 quarts
Automatic Transmission, 1000 Initial Fill..........7.4 quarts [2]
Automatic Transmission, Total Fill
6 speed 6L90..........12.4 quarts
6 speed 1000..........12.7 quarts
For the 2004-2005 Dmax, GM recommends either Fuel Efficient ATF or Torque Drive. For the 2006 Dmax, GM recommends Fuel Efficient ATF. That said, Allison Inc. recommends using a TES-295 equivalent fluid for use with extended service intervals.
AMSOIL Torque Drive is not listed in their product lookup guide for 2006 or newer becuase that guide is based on OEM recommendations. Those being from GM. Even though Allison still recommends a TES-295 fluid.
Please not that what Allison warrants or recommends, does not effect your GM warranty on the transmission. Not only that but, the warranty on non-upgraded transmissions cannot be voided by GM unless they can PROVE that the fluid that you put in it caused a malfunction should one occur.
Click Here For Transmission Flush Instructions
Click Here for the Hoot Flush Method.
DIFFERENTIALS:
Standard Differential, Rear......GL-5
All TEMPS......75W-90 [2]
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
Standard Differential, Front AWD 8.25 AXle......GL-5
TRANSFER CASE:
Transfer Case,NVG 149-NP3......GLS [5]
Synthetic Universal Automatic Transmission Fluid (ATFQT)
Transfer Case,NVG 246-NP8......SLF [6]
No AMSOIL Product Recommendation
Transfer Case,NVG 263-NP1......GLS [6]
Transfer Case,NVG 261-NP2......GLS [6]
Below are the fluid capacities for the differentials and transfer case:
Differential, With 8.25 RingGear Front..........3 pints
Differential, With 9.25 RingGear Front..........3.6 pints
Differential, With 8.6 RingGear Rear..........4.3 pints
Differential, With 9.50 RingGear Rear..........5.5 pints
Transfer Case, MVG261-NP2..........4.1 pints
Transfer Case, MP1222/1225..........3.2 pints
Transfer Case, MP1226-NQG..........3.2 pints
Transfer Case, MP1625/1626NQF..........3.2 pints
Transfer Case, MP3023-NQH..........3.2 pints
POWER STEERING:
Power Steering Fluid......PS
Power Steering Fluid (PSFCN)
To flush the power steering, I would have 3-4 bottles of fluid on hand for the entire process.
BRAKE FLUID:
Brake Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN)
To flush the brakes, I would have 4-5 bottles of fluid on hand for the entire process.
CLUTCH FLUID:
Clutch Fluid......HB
FILTERS:
OIL FILTERS:
AMSOIL Ea Oil Filter (EaO52)
AIR FILTER:
AMSOIL Currently Does not offer a factory replacement air filter for these "Some" of these trucks. Please contact us to find out more about your specific application.
INJEN/AMSOIL Cold Air Intake
FUEL FILTERS:
Donaldson P-Series Heavy Duty Fuel Filter #P550743
WIX 33960XE when available
TRANSMISSION FILTERS:
Internal Filter WIX 58970 Auto Tran Filter
Spin-on Filter WIX 57701 Hydraulic Filter
WIPER BLADES:
Exact Fit
Neoform
Winter
*OEM Design
CHASSIS LUBRICATION:
0-8 Fittings, 0 Plugs..........LB
Series 2000 Synthetic Racing Grease NLGI#2 GC/LB (GRGCR)
Synthetic Multi-Purpose Grease NLGI #2 GC/LB (GLCTB)
Synthetic Water Resistant Lithium Complex Grease; NLGI #2 GC/LB (GWRCR)
COOLING SYSTEM:
AMSOIL Antifreeze and Engine Coolant
Cooling System, Initial Fill..........25.4 quarts
Propylene Glycol can be mixed with other fluids but should be mixed with water as well and not used in its concentrated form.
TORQUE SPECS:
Oil Drain Plug.....62 ft/lbs
Transfer Case MP 1222
Fill Plug 13 ft/lbs
Drain Plug 13 ft/lbs
Transfer Case MP 1225
Fill Plug 13 ft/lbs
Transfer Case MP 1625
Fill Plug 13 ft/lbs
Transfer Case MP1226-NQG
Fill Plug 13 ft/lbs
Transfer Case MP1626-NQF
Fill Plug 13 ft/lbs
Transfer Case MP3023-NQH
Fill Plug 13 ft/lbs
Transfer Case NR3
Fill Plug 18 ft/lbs
Drain Plug 18 ft/lbs
Transfer Case NVG261-NP2
Fill Plug 15 ft/lbs
Drain Plug 15 ft/lbs
NOTES:
[1] Improves cold starting.
[2] Synthetic axle lubricant GM Part no. 89021677 / Canada
89021678 formulated to meet GM Specification 9986115.
[3] GM part no. 12378508 (U.S.), 10953626 (CAN)
[4] GM recommends Part No. 88861800 (Canada 88861801)
or equivalent for manual transmission, transfer case applications, however, consult MikeL about recommendations covering the use of Synthetic 5w-30 engine oil in the transfer case.
OTHER APPLICABLE PRODUCTS:
Mothers® Car Care Appearance Products
By-Pass Oil Filters
Diesel Fuel Additive Concentrate
Cold Flow Improver
Cetane Boost Diesel Fuel Additive
If I can provide wholesale pricing on any of these products, please PM me.
1 - 1 of 1 Posts
