1 - 16 of 16 Posts
wow that sounds pretty awful. bump for you. not sure what that could be
I forgot to mention this is not at idle the video was at about 1400rpms. It seems to follow the rpms. I'm not sure what it could be
I'm thinking bad injectors too I'm gonna see if I can get a tech 2 or something to get it figured out. Anybody else have any ways I can get them checked out?
BAD ASS LBZ that is
the noise you described in the intake sounds like it could be in need of valve adjustment or maybe a injector not seated in the injector cup properley and is blowing compression around the injector.
Is it a stock motor? stock fueling?
Ya it's a stock motor pretty much. Just installed a quadzilla stealth 2 the other day just to get readings. But other than that and a banks exhaust that's it.
another bump. Mind sounds like that, but not quite as loud. I have noticed it gets worse under load and towards the end of an oil change.
Hope you figure it out.
How old is the fuel filter/oil and filter? It may need to just be serviced. Mines gets cranky when she needs stuff lol
Just had oil changed and filter but you never know it could be the simplest of things. It's basically a really loud tick when under load and not as bad when idle. There's no metal in the oil and doesn't seem to have any fuel in it and no smoke out the exhaust so it cant be bad injectors can it?
Has a solution been found? I'm having the exact same sound on my '03 LB7.
yes it still can. I had no smoke, no fuel in oil and still had a bad injectors.
X2. I had zero signs just bad balance rates
That's sounds horrible it sounds like one of your injectors are bad.
1 - 16 of 16 Posts
