Which lift pump do you like?
  • Airdog
    Votes: 36 92.3%
  • PPE
    Votes: 3 7.7%
Status
Not open for further replies.
1 - 19 of 19 Posts
Im looking at buying a PPE lift pump and it would help if I had some pictures of the install to go off of....Thanks guys!
Pardon my ignorance, but what is a "lift pump"? Lifts your truk?
Gary
its mounted to the frame located under the driver's door area..it hooks into the fuel lines..it also seperates the air and water from the fuel..supposed to make ur pump and injectors last longer..
^^^^^^x2 also presurizes fuel lines so that you constantly getting fuel to your engine so that when you running a tune that needs more fuel you dont starve your engine of fuel which equals more performance....
thank you taysdmax, yes it does all of that too..it is recommended when running some higher settings with a programmer like the ppe..and if ur looking for an air dog, just look at some different sites and they should also come with detailed instructions on how to install..they do not take too long to install..:drink
Ok guys apreciate it...cant wait to get one cause driving on the high way and giving it some expecially when next to a tiny little ricer...I get irritated when I get to 70mph and the damn fail safe turns on...biggest pain in the ass ever...
where is the best place to buy one?
Ebay to be honest with you but if you dont like ebay any online diesel performance website they all have the same prices...
Its just a worktruck
I've installed a few but never took any pics.
You will need to go to the local hydraulic shop and get 2 fittings. Then get an A/C line quick disconnect tool and 8' of fuel line. Disconnect the OEM line from the sender to the fuel cooler. Save it. Mount pump in desired location. Run fuel line from sender to pump, then pump to cooler. Wire her up and you're good to go.
awesome thanks man...
i have a video on my cell phone i can send to ur email
airdog...thats what i am getting hands down
Discussion Starter · #14 ·
yea my stock lift pumps on its way out where can i find pictures. would be a big help
Im Superrrrr!
"Only How TO post belong in this forum!!! If your NOT showing/telling us HOW TO then DO NOT post it here."
Noomorereadrulez
saw what you did there
Searching the forum would be a start... :drink
something tells me it's not:rofl
You CP3 pump might be going out....a lift pump may solve your problems with that to though. It will take all the stress off of it from pulling the fuel all the way from the tank.
There is no stock lift pump. The only fuel pump our trucks have is the CP3 and its in the valley of the motor.
1 - 19 of 19 Posts
Status
