41 - 60 of 93 Posts
2006 LBZ 400K PowerHustler
Discussion Starter · #41 ·
hey there, im new to The forum.seen your post about diagrams and schematics and I was wondering if you could get the wiring schematics for a 2013 Chevy Silverado 2500 HD LTZ I need everything for a basement clusters the radio the nav systems the engine controls, the lights, pretty much the whole spiel if you got it. three-four mechanics on the truck tore up everything and mangled several wiring harnesses.
thank you appreciate this
respectfully,
Jeremy
I’m new to the forum and this is my first Duramax and diesel truck so I know next to nothing about it. I got a 2007.5 2500HD and wondering if you have the wiring diagram for the rear tail lights? My passenger side stopped working and both of the reverse lights stay on at all times and the brake light and turn signal won’t work on passenger side but when I put on the hazards or press my keyless entry they flash. I just installed a new pair of LED tail lights too to see if that’d fix the problem but still doing the same thing. I’m guessing I just need the wiring diagram for all the tail lights and also the 3rd brake light cuz that’s not working either. Thanks in advance!
Discussion Starter · #43 ·
GMC or Chevy questionmark. Anyways for chevy and GMC
Can I get the wiring diagrams for the transmission / transfer case / body control module (bcm) / C100 / C2 & C3 connector / Fuse Box / Instrument panel (ipc) / Fuel pump of a:
2006 Hummer H2 6.0, and the same schematics for a 2005 GMC 2500HD LLY Duramax?
I really appreciate it, thank you very much!
I just bought ProDemand, if you guys need anything let me know. I have the shop version, so 2001 to 2021 trucks just be specific on what you need.
I will ignore any post that wants every single diagram of their car. If you have a specific Electrical issue let me know. 2001 - 2007.5 are mostly the same.
Do you have the pin out diagrams for the LBZ c100 and c2 connectors?
I found these while I have been trying to resolve my issues...
Rectangle Material property Font Parallel Screenshot
Material property Rectangle Font Parallel Number
Rectangle Font Parallel Pattern Number
Rectangle Font Musical instrument Parallel Office equipment
Rectangle Parallel Font Pattern Number
The excel document I put togetherher as a shortcut for testing my injector circuits. Additionally I have a picture we took also showing the bail connectors and which injectors were grouped together. They share a common positive and have independent grounds. If you zoom in you can see the cylinder designations we wrote on the connections from testing them for continuity.
Automotive parking light Space bar Automotive lighting Grille Automotive tire
Discussion Starter · #49 ·
Connector Part Information
  • OEM: 15462694
  • Service: 88988935
  • Description: 58-Way F Sealed (BK)
Terminal Part Information
  • Pins: 1, 2, 3, 4, 5, 6
  • Terminal/Tray: 1928498059/24
  • Core/Insulation Crimp: C/5
  • Release Tool/Test Probe: J-38125-561/J-35616- 35(VT)
  • Terminal/Tray: 1928498135/19
  • Core/Insulation Crimp: Pins 9, 12, 13, 15, 16, 19, 21, 22, 27, 29–31, 33–36, 40, 42, 44–50, 54–58 – P/P
  • Core/Insulation Crimp: Pins 18, 23, 24, 38, 39 – See Terminal Repair Kit
  • Release Tool/Test Probe: J-38125-213/J-35616-64B (L-BU)
Engine Control Module (ECM) - C2
PinWire ColorCircuit No.Function
1
PK
339
Ignition 1 Voltage
2
BK/WH
451
Ground
3
PK
339
Ignition 1 Voltage
4
BK/WH
451
Ground
5
PK
339
Ignition 1 Voltage
6
BK/WH
451
Ground
7–8
Not Used
9
D-GN
1049
Class 2 Serial Data
10–11
Not Used
12
D-GN/WH
465
Fuel Pump Relay Control
13
BK
2751
Low Reference
14
Not Used
15
WH/BK
1164
5-Volt Reference
16
D-BU
507
Wait to Start Indicator Control
17
Not Used
18
PU
2562
PTO Control (PTO)
19
GY/BK
2219
ECM Relay Control
20
Not Used
21
PK
439
Ignition 1 Voltage
22
L-BU
1320
CHMSL Supply Voltage
23
BN
25
Charge Indicator Control
24
BN
2524
Generator 2 Turn On Signal (8X5/YF2)
25–26
Not Used
27
GY
2700
5-Volt Reference
28
Not Used
29
BN
1271
Low Reference
30
BN/WH
419
MIL Control
31
D-GN/WH
459
A/C Compressor Clutch Relay Control
32
Not Used
33
OG/BK
5764
EGR Motor High Control
34
BK
470
Low Reference
35
RD/BK
380
A/C Refrigerant Pressure Sensor Signal
36
PU/WH
1589
Fuel Level Sensor Signal - Primary (Early Production)
PU
1589
Fuel Level Sensor Signal - Primary (Late Production)
37
Not Used
38
GY
23
Generator Field Duty Cycle Signal
39
OG/BK
1786
Park/Neutral Signal (MW7)
40
PU
420
TCC Brake Switch/Cruise Control Release Switch Signal
41
Not Used
42
D-GN/WH
817
Vehicle Speed Signal
43
Not Used
44
TN
2501
High Speed GMLAN Serial Data Bus -
45
PU/WH
821
VSS High Signal (ML6)
45
YE
400
VSS High Signal (MW7)
46
L-GN/BK
5746
EGR Motor Low Control
47
BN
6062
Low Reference
48
YE
1578
Fuel Temperature Signal
49
D-BU
1161
APP Sensor 1 Signal
50
D-BU
1936
Fuel Level Sensor Signal - Secondary (Except NQZ)
51–53
Not Used
54
YE/BK
1827
55
WH
121
Engine Speed Signal
56
PK
1020
Ignition 0 Voltage
57
BN/WH
2500
High Speed GMLAN Serial Data Bus + (Early Production)
BN
2500
High Speed GMLAN Serial Data Bus + (Late Production)
58
L-GN/BK
822
VSS Low Signal (ML6)
Discussion Starter · #50 ·
1 C102
2 Fuse Block– Underhood Support Mount
3 C152
4 C100
C100 I/P Harness to Engine Harness
  • OEM: 15326084
  • Service: 15306348
  • Description: 16-Way F GT 150 280 Series Sealed 4.0 5.8 (BK)
  • OEM: 15326057
  • Service: 88987519
  • Description: 16-Way M GT 150 280 Series Sealed 4.0 5.8 (BK)
  • Pins: B, C, D, E, K, L, N, P, R
  • Terminal/Tray: 12191819/8
  • Core/Insulation Crimp: E/A
  • Release Tool/Test Probe: 15315247/J-35616-2A (GY)
  • Pins: A, H, J, S
  • Terminal/Tray: 15304719/19
  • Core/Insulation Crimp: E/5
  • Release Tool/Test Probe: 15315247/J-35616-4A (PU)
  • Pins: B, E, F, R
  • Terminal/Tray: See Terminal Repair Kit
  • Core/Insulation Crimp: See Terminal Repair Kit
  • Release Tool/Test Probe: See Terminal Repair Kit
  • Pins: B, C, D, E, F, K, L, M, N, P, R
  • Terminal/Tray: 15326269/19
  • Core/Insulation Crimp: E/4
  • Release Tool/Test Probe: 15315247/J-35616-3 (GY)
  • Pins: A, F
  • Pins: A, H, J, S
  • Terminal/Tray: 15304731/19
  • Release Tool/Test Probe: 15315247/J-35616-5 (PU)
PinWire ColorCircuit No.FunctionPinWire ColorCircuit No.Function
A
D-BU
84
Cruise Control Set/Coast Switch Signal (KUP)
A
D-BU
84
A
L-BU/BK
396
Cruise Control Engaged Signal (w/o KUP)
A
L-BU/BK
396
B
GY
48
CPP Switch Signal (ML6, MG5)
B
GY
48
B
PU
5526
Tap Up/Tap Down Switch Signal (MW7)
B
PU
5526
C
BN
241
Ignition 3 Voltage (TP2)
C
BN
241
D
D-GN/WH
817
D
D-GN/WH
817
E
D-BU
507
Wait to Start Indicator Control (Diesel)
E
D-BU
507
E
OG/BK
6752
Class 2 Serial Data (10 Series except HP2)
E
OG/BK
6752
F
TN/WH
2500
High Speed GM LAN Serial Data (+) (MW7)
F
TN
2500
G
TN
2501
High Speed GM LAN Serial Data (−) (MW7)
F
TN
2501
H
D-GN
1049
Class 2 Serial Data
H
D-GN
1049
Class 2 Serial Data
J
BN/WH
419
MIL Control
J
BN/WH
419
MIL Control
K
WH
121
Engine Speed Signal
K
WH
121
Engine Speed Signal
L
GY
397
Cruise Control ON Switch Signal (K34)
L
GY
397
M
Not Used
M
YE
710
Class 2 Serial Data (HP2/8.1L)
M
Not Used
M
PK/WH
1101
Damping Lift/Drive Signals (Except HP2/8.1L)
N
BN
241
Ignition 3 Voltage (NP1, NP2, and NP8)
N
BN
241
P
D-BU
204
A/C Low Pressure Sensor Signal (CJ2/CJ3)
P
D-BU
204
R
BK/WH
5668
Engine On Signal (JC4)
R
D-BU
5668
R
YE
2470
Class 2 Serial Data (MW7)
R
YE
2470
S
GY/BK
87
Cruise Control Resume/Accel Switch Signal
S
GY/BK
87
@PowerHusler - Im sure your probably busy but I send you a DM to see if you might be able to help me get these diagrams; No worries if not, just trying to save the cost of purchasing two alldatadiy subscriptions.
Discussion Starter · #52 ·
Do you want the BCM wiring diagrams or connector pinouts? And for what transmission do you need diagrams for? GM or Allison?
Discussion Starter · #53 ·
ONLY FOR 2005 GMC BCM
Computer/Integrating Systems Connector End Views
Body Control Module (BCM) – C1
  • 12177194
  • 6-Way F Metri-Pack 150 Series (NA)
Pin
Wire Color
Circuit No.
Function
A
RD
2353
Instrument Panel Lamps Dimming Supply Voltage
B
PU/WH
1382
LED Dimming Signal
C
OG
4040
Battery Positive Voltage
D
OG
1732
Inadvertent Power Courtesy Lamps Supply Voltage
E
BN/WH
230
Instrument Panel Lamps Dimming Control
F
OG
2240
Body Control Module (BCM) – C2
  • 12110088
  • 24-Way F Micro-Pack 100 Series (GY)
Pin
Wire Color
Circuit No.
Function
A1
Not Used
A2
D- BU
1796
Steering Wheel Radio Controls Supply Voltage (UK3)
A3
D-BU
245
Passenger Door Lock Switch Unlock Control - Base
TN/BK
254
Rear Door Unlock Relay Control - Uplevel
A4
PK/WH
1970
Headlamp Low Beam Relay Control
A5
D-GN/WH
1317
Fog Lamp Relay Control
A6
L-BU
244
Passenger Door Lock Switch Lock Control - Base
GY/BK
255
Rear Door Lock Relay Control - Uplevel
A7
Not Used - Uplevel
L-GN
1391
Driver Door Unlock Relay Control - Base
A8
WH
193
Rear Defog Relay Control
A9–A10
Not Used
A11
RD/WH
812
12 Volt Reference
A12
OG
1140
B1
BK/WH
1969
Headlamp High Beam Relay Control
B2
WH
1080
Park Lamp Relay Control
B3
D-BU
1353
RAP Supply Voltage
B4
L-GN/BK
592
DRL Relay Control
B5
PU
359
DRL Off Indicator Control
B6
BK/WH
1851
Ground
B7
BK
1835
Security System Sensor Low Reference
B8
PK
1348
Headlamp On Indicator Control
B9
BK
28
Horn Relay Control
B10
Not Used
B11
GY
1056
Dimming Potentiometer 5-Volt Reference
B12
L-GN
1037
BCM Class 2 Serial Data
Body Control Module (BCM) – C3
  • 12160778
  • 24-Way F Micro-Pack 100 Series (BN)
Pin
Wire Color
Circuit No.
Function
A1–A3
Not Used
A4
WH
278
Ambient Light Sensor Signal
A5
Not Used - w/o CJ2
GY
1548
Passenger Sunload Sensor Signal - CJ2
A6
YE
1836
Security System Sensor Signal
A7
Not Used - Base
L-GN
1011
Remote Radio Control Signal (UK3)
A8
D-GN
588
DRL Switch Signal
A9
OG
192
Front Fog Lamp Switch Signal
A10
Not Used
A11
PU
328
Interior Lamp Defeat Switch Signal
A12
Not Used
B1
Not Used
B2
GY/BK
308
Park Lamp Switch Signal
B3–B4
Not Used
B5
Not Used - w/o CJ2
L-BU/BK
590
Driver Sunload Sensor Signal - CJ2
B6
BK/WH
1851
Ground
B7
Not Used
L-BU
1059
Steering Wheel Position Sensor Signal - NYS
B8
OG/BK
2090
Dimming Switch Signal
B9
L-GN
11
Headlamp Dimmer Switch Signal
B10
Not Used
B11
L-BU
553
Tow/Haul Switch Signal
B12
Not Used
Body Control Module (BCM) – C4
  • 12110206
  • 24-Way F Micro-Pack 100 Series (L-BU)
Pin
Wire Color
Circuit No.
Function
A1
L-GN
80
Key In Ignition Switch Signal
A2
YE
307
Headlamp Switch Flash to Pass Signal
A3
WH
530
Off/Run/Crank Voltage
A4
PK
39
Ignition 1 Voltage
A5
Not Used - Uplevel
BK/WH
746
Right Front Door Ajar Switch Signal – Base
A6
D-BU/WH
149
Cargo Lamp Low Control
A7
L-BU
1134
Park Brake Switch Signal
A8
GY
1524
Backup Lamp Signal
A9–A11
Not Used
A12
WH
103
Headlamp Switch Headlamps On Signal
B1–B2
Not Used
B3
YE
43
Accessory Voltage
B4
Not Used - Uplevel
GY/BK
745
Left Front Door Ajar Switch Signal - Base
B5
Not Used - Uplevel
L-BU
195
Door Lock Control - Base
B6
GY/BK
2226
Instrument Panel Lamps Dimmer Switch Low Reference
B7
BK
279
Ambient Light Sensor Low Reference
B8
Not Used
B9
D-BU/WH
1495
Courtesy Lamps On Signal
B10
Not Used - Uplevel
WH
194
Door Unlock Control - Base
B11–B12
Not Used
Body Control Module (BCM) – C5
  • 12177195
  • 6-Way F Metri-Pack 150 Series (BK)
Pin
Wire Color
Circuit No.
Function
A–C
Not Used
D
OG
2140
E
GY/BK
690
Courtesy Lamp Control
F
L-GN
24
Backup Lamp Supply Voltage
Body Control Module (BCM) – C6
  • 12191375
  • 16-Way F Micro-Pack 100 Series (PU)
Pin
Wire Color
Circuit No.
Function
A1
Not Used
A2
L-GN/BK
748
Right Rear Door Ajar Switch Signal
A3
L-BU/BK
747
Left Rear Door Ajar Switch Signal
A4
Not Used
A5
Not Used - Base
L-BU
2265
Power Window Lockout Left Rear Control - Uplevel
A6
Not Used - Base
L-GN
2266
Power Window Lockout Right Rear Control - Uplevel
A7
Not Used - Base
GY/BK
1186
Power Window Relay Right Rear Up Control - Uplevel
A8
Not Used - Base
D-GN
1188
Power Window Relay Right Rear Down Control - Uplevel
B1–B6
Not Used
B7
Not Used - Base
YE
1187
Power Window Relay Left Rear Down Control - Uplevel
B8
Not Used - Base
WH
1185
Power Window Relay Left Rear Up Control - Uplevel
Discussion Starter · #54 ·
2005 gmc only
Left Side of the Engine– Diesel
1 A/C Compressor Clutch Connector
2 A/C Refrigerant Pressure Sensor Connector
3 Intake Air Temperature (IAT)/Mass Air Flow (MAF) Sensor Connector
4 Generator– Left Connector
5 Coolant Level Switch
6 C108
7 A/C Low Pressure Switch Connector
8 S118
9 C107
10 Throttle Actuator Control (TAC) Module Connector
11 Backup Lamp Switch Connector
12 Vehicle Speed Sensor (VSS) Connector
13 S127
14 C100
15 Fuse Block– Underhood C2
16 G104
17 C152
18 S103
19 Engine Control Module (ECM) C1 Connector
20 Engine Control Module (ECM) C2 Connector
21 Engine Control Module (ECM) C3 Connector
22 S164
23 S102
24 S148
25 S147
26 S119
27 Generator– Right Connector
Right Side of the Engine– Diesel
1 S127
2 Throttle Actuator Control (TAC) Module Connector
3 C108
4 C107
5 C153
6 C100
7 Fuse Block– Underhood C2
8 C152
9 Glow Plug Controller Power
10 Generator– Right Connector
11 S141
12 A/C Refrigerant Pressure Sensor Connector
13 Engine Control Module (ECM) C3 Connector
14 Engine Control Module (ECM) C2 Connector
15 Engine Control Module (ECM) C1 Connector
16 A/C Compressor Clutch Connector
17 Generator– Left Connector
18 Intake Air Temperature (IAT)/Mass Air Flow (MAF) Sensor Connector
19 G102
20 Coolant Level Switch Connector
21 A/C Low Pressure Switch Connector
I have a 2002 GMC Sierra 2500 HD with a manual transmission. Truck would not start and I isolated it to the clutch position sensor. But a new one in, but still didn’t work. Bypassed the switch so truck starts, but would like schematic for the switch to try and figure out where the underlying issue is. Thanks in advance for any and all help.
Could I get the wiring diagram for my 2019 Silverado 2500 6.6L need the glow plug diagram? Thanks in advance
Discussion Starter · #58 ·
Discussion Starter · #59 ·
K34 Glow Plug Control Module X2 (L5P)
  • Harness Type: Engine Chassis
  • OEM Connector: 10023701
  • Service Connector: 13576417
  • Description: 43-Way F 1.2, 2.8 Series, Sealed (BK)
Terminal Type IDTerminated LeadDiagnostic Test ProbeTerminal Removal ToolService TerminalTray NameCore CrimpInsulation Crimp
I
13576372
J-35616-4A (PU)
J-38125-556
Not Available
Not Available
Not Available
Not Available
II
13580008
J-35616-16 (LT GN)
J-38125-21
Not Available
Not Available
Not Available
Not Available
PinSizeColorCircuitFunctionTerminal Type IDOption
1
Not Occupied
2 2
2 2
2 GY/YE
2 1584
2 Glow Plug Control 4
2 I
2 L5P
3 3
3 2
3 GY/GN
3 1583
3 Glow Plug Control 3
3 I
3 L5P
4 4
4 2
4 GY/BN
4 1582
4 Glow Plug Control 2
4 I
4 L5P
5 5
5 2
5 GY/BU
5 1581
5 Glow Plug Control 1
5 I
5 L5P
6 - 9
Not Occupied
10 10
10 2
10 BK
10 550
10 Ground
10 I
10 L5P
11
Not Occupied
12 12
12 2
12 GY/WH
12 1585
12 Glow Plug Control 5
12 I
12 L5P
13 13
13 2
13 GY/VT
13 1586
13 Glow Plug Control 6
13 I
13 L5P
14 14
14 2
14 WH/BK
14 1587
14 Glow Plug Control 7
14 I
14 L5P
15 15
15 2
15 WH/BU
15 1588
15 Glow Plug Control 8
15 I
15 L5P
16 16
16 0.5
16 BK
16 C92
16 Intake Air Heater Current Feedback Signal
16 II
16 L5P
17 17
17 0.5
17 BK
17 C93
17 Intake Air Heater Digital Response Signal
17 II
17 L5P
18 18
18 0.5
18 WH
18 2501
18 High Speed GMLAN Serial Data (-) 1
18 II
18 L5P
19 19
19 0.5
19 WH
19 2501
19 High Speed GMLAN Serial Data (-) 1
19 II
19 L5P
20 - 22
Not Occupied
23 23
23 0.5
23 BK
23 D23
23 Intake Air Heater Voltage Feedback Signal
23 II
23 L5P
24 24
24 0.5
24 BK
24 D24
24 Intake Air Heater Temperature Signal
24 II
24 L5P
25 25
25 0.5
25 BU
25 2500
25 High Speed GMLAN Serial Data (+) 1
25 II
25 L5P
26 26
26 0.5
26 BU
26 2500
26 High Speed GMLAN Serial Data (+) 1
26 II
26 L5P
27 - 29
Not Occupied
30 30
30 0.5
30 BK
30 D30
30 Intake Air Heater Switch On/Off Signal
30 II
30 L5P
31 31
31 0.5
31 BK
31 D31
31 Intake Air Heater Heart Beat Signal
31 II
31 L5P
32
Not Occupied
33 33
33 0.5
33 VT/BK
33 2139
33 Run/Crank Ignition 1 Voltage
33 II
33 L5P
34 - 36
Not Occupied
37 37
37 0.5
37 BK
37 D37
37 NOx Sensor 1 Control
37 II
37 L5P
38 38
38 0.5
38 BK
38 D38
38 NOx Sensor 2 Control
38 II
38 L5P
39
Not Occupied
40 40
40 0.5
40 VT/YE
40 443
40 Accessory Ignition Voltage
40 II
40 L5P
41 - 43
Not Occupied
I have a 2019 2500 Duramax. I am looking for the Drivers Door "Open" wiring (Sensor) circuit.
If you Could you please. Thanks
41 - 60 of 93 Posts
