61 - 80 of 93 Posts
I just bought ProDemand, if you guys need anything let me know. I have the shop version, so 2001 to 2021 trucks just be specific on what you need.
I will ignore any post that wants every single diagram of their car. If you have a specific Electrical issue let me know. 2001 - 2007.5 are mostly the same.
Looking for the wiring diagram for a 2005 silverado, ext. cab... chasing a wiring gremlin i believe is connected to a ground issue so primarily im just looking to see if theres a ground diagram? But otherwise if there is a diagram for the main harness or the fuse block under the hood, that would be awesome..
Like i said, chasing a gremlin.. lol
TIA
2006 LBZ 400K PowerHustler
Discussion Starter · #62 ·
TIA
Taking a brake until Monday .
Hey I have a 2003 lb7 just swapped and put a lly in it out of a 04 I used the Arnes off the LLy motor it pins looked the same just want to make sure everything is right plugs into the fuse box and then goes down plugs into the transmission I’m geting a bunch of codes Security issues throttle position garbage etc.
Looking for ABS wiring diagram for my 2007 Classic Duramax. Any help would be appreciated.
Hey powerhusler
I need an airbag wiring diagram for my 2008 chevy 3500hd duramax. Thanks for all your help and info brother. Ive a no communication and ive done the basics,clean grounds look for damaged or corroded connectors in the plugs also was scanned using a snap-on reader.
I'm not sure where to start but here goes, I have a battery draw problem, park the truck overnight and it will not start with out using a jump box? When I put the jump box on the battery it shows how much voltage is in the battery and it is never lower than 9.5 volts, something pulls the battery down that far and then it must shut off. Just before the problem started the bed was removed and reinstalled, I don't know if this had anything to do with it or not. I don't know if you might have any ideas about it or not but when I saw this thread I thought that I would ask.
Looking to run a kicker hideaway speaker in my new 2021 AT4 1500. Wanting to know if there is a sub output. Do you have a diagram that shows the radio wires? It is a non Bose system
We have a 2008 Silverado 3500 Duramax Dually. We are having a problem that we we go down the road with the high-beams on, the lights (High Beams) on the passenger side flicker when you go over bumps. The signal indicator in the passenger side mirror flickers at exactly the same time; when the headlights flick dim, the passenger mirror signal indicator flicks on at the exact same time. We've also observed that the hood latch open indication comes on repeatedly when the flickering is happening. No hood latch open warnings when driving with low beams only.
A couple of other things. We've been seeing cam sensor (or crank sensor) warning code at times as well as a low oil pressure code. We had a scanner run on it and seemed to be generating good high fuel pressure readings (~9000 psi at idle, ~25000 psi when driving).
These problems happen in either Drive or Neutral. We've tried jiggling lots of wires in the engine compartment when in park but are not able to make the problems above repeat.
Do you have any idea where we can look to observe this voltage while driving.
Thanks
Discussion Starter · #72 ·
Electronic Brake Control Module (EBCM)
1 Electronic Brake Control Module (EBCM)
2 Electronic Brake Control Module (EBCM) Electrical Connector — C1
3 Electronic Brake Control Module (EBCM) Electrical Connector — C2
4 Frame
Traction Control Switch (NW7)
1 Traction Control Switch
2 Instrument Panel Outer Air Outlet Housing
Wheel Speed Sensor (WSS)– RF and LF
1 Wheel Speed Sensor (WSS)– RF
2 Wheel Speed Sensor (WSS)– LF
Send me a picture of the EBCM connector. There is two different connectors, and I need to make sure I give you the correct one.
4 Frame
4 Frame
Automotive fuel system Automotive tire Motor vehicle Coil Bumper
Cruise control also isn’t working not sure if thats linked with an abs light. Brake switch has been replaced and rear lights are working.
Discussion Starter · #74 ·
Connector Part Information
  • OEM: 15339077
  • Service: 88986458
  • Description: 20-Way F Micro-Pack 100W (BK)
Terminal Part Information
  • Terminal/Tray: 12084913/5
  • Core/Insulation Crimp: W/W
  • Release Tool/Test Probe: 12122523/J-35616-6 (BN)
Electronic Brake Control Module (EBCM) C2 (Greater Than 8600 GVW)
PinWire ColorCircuit No.Function
A1
YE
873
Left Front Wheel Speed Sensor Low Reference
A2
D-GN
872
Right Front Wheel Speed Sensor Signal
A3
PU
420
TCC Brake Switch/Cruise Control Release Signal
A4–A6
Not Used
A7
TN/BK
464
Delivered Torque Signal (NW7)
A8
BK/WH
1695
Axle Switch Signal (w/o NW7)
A9
L-BU
1122
Class 2 Serial Data
A10
PU
333
Brake Fluid Level Sensor Signal
B1
L-BU
830
Left Front Wheel Speed Sensor Signal
B2
TN
833
Right Front Wheel Speed Sensor Low Reference
B3
YE/BK
1827
Vehicle Speed Signal
B4
BN/WH
1571
Traction Control Switch Signal (NW7)
B5–B6
Not Used
B7
OG/BK
463
Requested Torque Signal (NW7)
B8–B9
Not Used
B10
BN
441
Ignition 3 Voltage
Since you don't have RPO Code NW7, just ignore the ones labeled on the pinout (Only for gas). And yes, ABS is linked to cruise control.
2003 3500 silverado lb7
If you guys need any diagrams let me know. Anything from 2001 to 2019 trucks just be specific on what you need.
I'm looking to install a remote start in my 2003 3500 lb7 silverado crew cab longe bed dually. Not entirely sure which wire diagrams I will need for it but whatever diagram that shows everything under the steering wheel would be a start.
Thanks for any help
Discussion Starter · #76 · (Edited)
Thanks for any help
Send me a picture
Hey powerhusler
Sierra/Silverado
Click to Enlarge
1 Inflatable Restraint Front End Sensor-Right-1500-Located on the front frame crossmember.
2 Battery-Gas-Located under the hood, right rear engine compartment.
3 Inflatable Restraint I/P Module-Located at the right front of the instrument panel cluster (IPC).
4 Inflatable Restraint Instrument Panel Module Disable Switch-Located inside instrument panel (I/P) storage compartment.
5 Inflatable Restraint Side Impact Sensor (SIS)-RF-Located under the right front door trim near the lower rear of the door frame.
6 Inflatable Restraint Passenger Presence System (PPS)-Right-Located under the right front seat cushion.
7 Inflatable Restraint Passenger Presence System (PPS)-Located under the right front seat mounted to the seat frame.
8 Inflatable Restraint Seat Belt Pretensioner-Right-Located on the right front B Pillar.
9 Inflatable Restraint Side Impact Sensor (SIS)-LRR-Located under the right rear door trim near the lower rear of the door frame.
10 Inflatable Restraint Roof Side Rail Module-Right -Located under the headliner.
11 Inflatable Restraint Seat Belt Tension Retractor Sensor-Located on the inboard lower seat belt buckle.
12 Inflatable Restraint Vehicle Rollover Sensor-Located under the center console.
13 Inflatable Restraint Roof Rail Module-Left-Located in the headliner.
14 Inflatable Restraint Side Impact Sensor (SIS)-LR-Located under the left rear door trim near the lower rear of the door frame.
15 Inflatable Restraint Seat Belt Pretensioner-Left-Located on the left front B Pillar.
16 Inflatable Restraint Sensing and Diagnostic Module (SDM)-Located under the left front seat under the carpet.
17 Inflatable Restraint Seat Position Sensor (SPS)-Left-Located on the left front inboard seat track.
18 Inflatable Restraint Side Impact Sensor (SIS)-LF-Located under the left front door trim near the lower rear of the door frame.
19 Inflatable Restraint Steering Wheel Module-Located on the steering wheel.
20 Inflatable Restraint Panel Module Indicator (AIRBAG ON/OFF)-overhead console.
21 Battery-Diesel-Located under the hood, left front engine compartment.
22 Inflatable Restraint Front End Sensor-Left-1500-Located on the front frame crossmember.
23 Inflatable Restraint Front End Sensor-Center-Located on the front frame crossmember
Discussion Starter · #79 ·
@Rmm_jr
As requested
Fuse Block – Underhood Bottom View
Fuse Block – Underhood C1
Fuse Block – Underhood C2
  • OEM: 12193905
  • Service: 12193905
  • Description: 68-Way F Metri-Pack 280 Series Flexlock (GY)
  • Terminal/Tray: See Terminal Repair Kit
  • Core/Insulation Crimp: See Terminal Repair Kit
  • Release Tool/Test Probe: See Terminal Repair Kit
A1–A2
Not Used
A3
YE
5
Crank Voltage
A4
Not Used
A5
OG
4340
Battery Positive Voltage
A6
PK
39
Ignition 1 Voltage
A7
YE
1139
Ignition 1 Voltage
YE
1139
Ignition 1 Voltage (C99)
A8
L-GN/BK
584
A/T Shift Lock Control Switch Supply Voltage (A/T)
A9
PK
3
Ignition 1 Voltage
A10
Not Used
A11
D-GN
1433
Park/Neutral Start Switch Signal (MG5/ML6/MW3/MW7)
A12
BN
2409
Interior Park Lamps Supply Voltage
BN
2409
B1
OG
1640
Battery Positive Voltage (NP8)
B2
OG
2268
Windshield Washer Relay Control
B3
D-GN/WH
1317
Fog Lamp Relay Control (T96)
D-GN/WH
1317
B4–B7
Not Used
B8
OG
1840
B9
BK/WH
1969
Headlamp Relay Control/Headlamp High Beam Relay Control
B10
Not Used
B11
OG
3840
Battery Positive Voltage (CF5)
B12
RD
142
C1
OG
1640
C2
OG
3240
C3
BK
28
Horn Relay Control
BK
28
Horn Relay Control
C4–C5
Not Used
C6–C7
Not Available
C8
Not Used
C9
PK
1020
Ignition 0 Voltage
C10
OG
1040
C11
Not Used
C12
PU
420
D1–D2
Not Used
D3
PK/WH
1970
Headlamp Low Beam Relay Control
D4
OG
340
OG
340
Battery Positive Voltage (UQ3/UQ5/UQ7)
D5
OG
640
OG
640
D6–D7
Not Available
D8–D9
Not Used
D10
PK
639
Ignition 1 Voltage
D11
Not Used
D12
OG
1140
Battery Positive Voltage – BCM
E1–E2
Not Used
E3
L-GN /BK
592
DRL Relay Control
E4
OG
4540
Battery Positive Voltage (8S8)
OG
4540
E5
Not Used
E6
BN/WH
1571
E7
L-BU
1320
CHMSL Supply Voltage/Stop Lamp Supply Voltage
E8
Not Used
E9
D-GN
591
Ignition 1 Voltage (HP2)
E10
D-BU
2115
Right Turn Signal Lamps Supply Voltage
E11
OG
2340
E12
Not Used
F1
PK
139
Ignition 1 Voltage (w/JC4 or w/o NQZ)
F2
OG
3740
F3
L-BU
2114
Left Turn Signal Lamps Supply Voltage
F4
Not Used
F5
PK
739
Ignition 1 Voltage (8S8)
PK
739
Ignition 1 Voltage
F6
PK
639
Ignition 1 Voltage (w/o 8S8)
PK
639
Ignition 1 Voltage (Except Diesel/8.1L w/MW7)
F7
OG
2840
Battery Positive Voltage (w/o 8S8)
F8–F9
Not Used
F10
GY
1524
Backup Lamp Supply Voltage (w/o MW7)
L-GN
24
Backup Lamp Supply Voltage (MW7)
L-GN
24
F11
WH
1080
Park Lamp Relay Control
F12
OG
1540
Fuse Block – Underhood C3
  • OEM: 12193906
  • Service: 12193906
  • Description: 68-Way F Metri-Pack 280 Series (BK)
A1–A2
Not Used
A3
D-GN
59
A/C Compressor Clutch Supply Voltage (CJ2/CJ3)
A4–A6
Not Used
A7
D-GN/WH
465
Fuel Pump Relay Control – Primary
A8
Not Used
A9
PK
1339
Ignition 1 Voltage
A10
L-BU
1320
CHMSL Supply Voltage/Stop Lamp Supply Voltage (KUP)
A11
GY
1524
Backup Lamp Supply Voltage Signal (Diesel)
GY
1524
Trailer Backup Lamp Supply Signal
A12
PK
439
Ignition 1 Voltage (L59)
PK
439
Ignition 1 Voltage (EVA)
B1
Not Used
B2
OG
3440
Battery Positive Voltage (8.1L/PTO)
B3
BK/WH
1695
Axle Switch Signal
BK/WH
1695
Axle Switch Signal
B4–B6
Not Used
B7
BK
550
Ground
B8
OG
440
OG
440
B9
PK
1039
Ignition 1 Voltage
PK
1039
Ignition 1 Voltage (Diesel)
B10
PK
439
Ignition 1 Voltage – MAF/IAT Sensor (Gas)
PK
439
Ignition 1 Voltage – PCM (Gas)
B11–B12
Not Used
C1–C2
Not Used
C3
D-GN/WH
459
A/C Compressor Clutch Relay Control (CJ2/CJ3)
C4–C5
Not Used
C6–C7
Not Available
C8–C9
Not Used
C10
PK
1039
Ignition 1 Voltage (Except 4.3L)(Gas)
PK
1039
Ignition 1 Voltage (Gas)
C11
Not Used
C12
PU
420
PU
420
TCC Brake Switch/Cruise Control Release Signal (MW7)
D1–D2
Not Used
D3
L-GN
275
Park Neutral Position Switch Park Signal
D4
Not Used
D5
RD/WH
4740
Battery Positive Voltage (10 Series Except HP2)
RD/WH
4740
D6–D7
Not Available
D8
PK
539
Ignition 1 Voltage – HO2S Bank 1 Sensor 1(Gas except HP2)
PK
539
Ignition 1 Voltage – HO2S Bank 2 Sensor 1(Gas except HP2)
PK
239
PK
239
D9
PK
1239
PK
339
PK
339
D10
PK
1039
PK
1039
D11
PU
6
Starter Solenoid Crank Voltage (w/o HP2)
D12
YE/BK
625
Starter Enable Relay Control (Except HP2)
E1–E5
Not Used
E6
PK
1239
Ignition 1 Voltage – Fuel Injector 2 (Gas)
PK
1239
Ignition 1 Voltage – Fuel Injector 4 (Gas)
GY/BK
2219
FICM Relay Control (Diesel)
E7
PK
1539
Ignition 1 Voltage – HO2S – Bank 1 Sensor 2 (Gas except HP2)
PK
1539
Ignition 1 Voltage – HO2S – Bank 2 Sensor 2 (Gas except HP2)
PK
439
Ignition 1 Voltage – MAF/IAT Sensor (Diesel)
PK
439
Ignition 1 Voltage – ECM (Diesel)
E8–E9
Not Used
E10
PK
1239
Ignition 1 Voltage (Gas) (Except 4.3L)
PK
1239
E11
PK
1020
Ignition 0 Voltage (A/T Except MW7)
PK
1020
Ignition 0 Voltage
E12
Not Used
F1–F2
Not Used
F3
PU
806
Crank Voltage
PU
806
Crank Voltage (MW7)
F4
OG
4440
Battery Positive Voltage (MW7)
OG
4440
F5–F7
Not Used
F8
PK
839
Ignition 1 Voltage
F9
PK
639
Ignition 1 Voltage (GAS)
F10
PK
1020
Ignition 0 Voltage
PK
1020
Ignition 0 Voltage (MW7 or HP2)
F11
D-GN
1433
Park/Neutral Start Switch Signal (Except HP2)
BK
550
Ground (Diesel w/MW7)
PK
639
Ignition 1 Voltage (8.1L w/MW7)
F12
Not Used
Fuse Block – Underhood C4
  • OEM: 12193916
  • Service: 12193916
  • Description: 32-Way F Metri-Pack 280 Series (RD)
  • Pins: A3–A5, B1, B3, B6, C2, C6, E4, F1, F4, F6
  • Terminal/Tray: 12110844/4
  • Core/Insulation Crimp: Pins A3, B3, B6, C2, C6, F1, F4, F6 – C/A
  • Core/Insulation Crimp: Pins A4, A5, B1, E4 – E/A
  • Release Tool/Test Probe: 15315247/J-35616-4A (PU)
  • Pins: C3–C4, D3–D4
A1–A2
Not Used
A3
D-BU
2115
A4
OG
2640
Battery Positive Voltage (Gas)
A5
PU
420
A6
Not Used
B1
BK/WH
1695
Axle Switch Signal (NP2)
B2
Not Used
B3
L-BU
2114
B4–B5
Not Used
B6
BN
2109
Trailer Park Lamps Supply Voltage
C1
Not Used
C2
L-GN
1624
Trailer Backup Lamps Supply Voltage (8S3)
L-GN
1624
C3–C4
Not Available
C5
Not Used
C6
BN/WH
2609
Right Rear Park Lamps Supply Voltage
D1–D2
Not Used
D3–D4
Not Available
D5–D6
Not Used
E1–E3
Not Used
E4
BK
550
Ground
E5–E6
Not Used
F1
GY
120
Fuel Pump Supply Voltage
GY
120
Fuel Pump Supply Voltage (Except NQZ)
F2–F3
Not Used
F4
L-BU
1320
F5
Not Used
F6
BN
2509
Left Rear Park Lamps Supply Voltage
Fuse Block – Underhood C5
  • OEM: 12193914
  • Service: 12193914
  • Description: 32-Way F Metri-Pack 280 Series (GN)
  • Pins: A3–A6, B2, C1, C5–C6, E1–E3, F4–F5
  • Core/Insulation Crimp: Pins A3, C1, C5, E1, F4–F5 – C/A
  • Core/Insulation Crimp: Pins A4, A6, B2, C6, E2–E3 – E/A
  • Pins: C3–C4, D3–D6
  • Terminal/Tray: 12110842/4
A1–A2
Not Used
A3
D-BU
2115
D-BU
2115
A4
BK
550
Ground
BK
550
Ground
A5
Not Used
A6
D-GN
1329
Left Horn Fuse Supply Voltage
D-GN
1329
Right Horn Fuse Supply Voltage
B1
Not Used
B2
D-BU
545
Left DRL Supply Voltage
D-BU
545
Right DRL Supply Voltage
B3–B6
Not Used
C1
BN
2309
Left Front Park Lamps Supply Voltage
BN
2309
Right Front Park Lamps Supply Voltage
C2
Not Used
C3–C4
Not Available
C5
BN
2309
BN
2309
C6
RD
228
Windshield Washer Pump Control
D1–D2
Not Used
D3–D4
Not Available
D5
Not Used
D6
PU
34
Left Fog Lamps Supply Voltage (T96)
PU
34
Right Fog Lamps Supply Voltage (T96)
E1
L-BU
2114
L-BU
2114
E2
D-GN/WH
711
Left Headlamp High Beam Supply Voltage
E3
L-GN/BK
311
Right Headlamp High Beam Supply Voltage
E4–E6
Not Used
F1–F3
Not Used
F4
YE
712
Left Headlamp Low Beam Supply Voltage
F5
TN/WH
312
Right Headlamp Low Beam Supply Voltage
F6
Not Used
Fuse Block – Underhood C6
  • OEM: 15393171
  • Service: 88986444
  • Description: 2-Way F J-Type (GY)
  • Terminal/Tray: 12110127/19
  • Core/Insulation Crimp: F/G
  • Release Tool/Test Probe: 12150860/J-35616-44 (YE)
A
RD
842
B
RD
542
Fuse Block – Underhood C7
  • OEM: 15393172
  • Service: 88986445
  • Description:
A
RD
642
B
Not Used
Fuse Block – Underhood C9
  • OEM: 15393168
  • Service: 88986443
  • Description: 2-Way F J-Type (BK)
A
RD
342
RD
342
Battery Positive Voltage (HP2)
B
RD
42
Electrical Center Identification Views
Fuse Block – Underhood Label
Fuse Block – Underhood Top View
Fuse Block – Underhood Label Usage
DeviceRatingDescription
STUD 1 Fuse
Trailer Wiring, Auxiliary Battery Relay and Battery Right – TP2, AUX HTR PMP Fuse – HP2, ESCM Fuse – HP2, HCM-B Fuse – HP2 and TRANS PUMP Fuse – HP2
MBEC 1 Fuse
50A
SEAT CB, RT DOOR CB
BLWR Fuse
40A
Blower Motor
LBEC 2 Fuse
50A
LCKS Fuse, DDM Fuse, PDM Fuse, ECC/TPM Fuse, AUX PWR 2 Fuse
STUD 2 Fuse
30A
Trailer Wiring, Emergency Vehicle Roof Lamp Relay – 5YO
ABS Fuse
60A
VSES/ECAS Fuse
60A
Not Used
IGN A Fuse
40A
Ignition Switch RUN, START, RUN/START/ACCY, STRTR Relay
IGN B Fuse
40A
Ignition Switch RUN/ACC, RUN/START
LBEC 1 Fuse
50A
HAZRD Fuse, TBC 2A Fuse, TBC 2B Fuse, TBC 2C Fuse, LT DOORS C.B.
TRL PARK Fuse
15A
Trailer Wiring
RR PARK Fuse
10A
Exterior Lamps – Right Rear, Clearance Lamps – Right
LR PARK Fuse
10A
Exterior Lamps – Left Rear, Clearance Lamps – Left
PARK LP Relay
TRL PARK Fuse, LR PARK Fuse, RR PARK Fuse, FRT PARK Fuse, INT PARK Fuse
STRTR Relay
Starter
INTPARK Fuse
10A
Power Take-Off (PTO) Switch, Inflatable Restraint I/P Module Disable Switch, HD Trailering Equiptment Provisional – Z82
STOP LP Fuse
25A
Stop Lamp Switch
TBC BATT Fuse
10A
Body Control Module (BCM)
S/ROOF Fuse
25A
Sunroof Module Control
SEO B2 Fuse
30A
Roof Beacon Relay – 5G4
4WS Fuse
15A
Evaporative Emission (EVAP) Canister Vent Solenoid
RR HVAC
30A
Not Used
AUX PWR Fuse
20A
Accessory Power Outlets, Auxiliary Power Outlets
PCM 1 Fuse
15A
Powertrain Control Module (PCM), Mass Air Flow (MAF) Sensor, Evaporative Emission (EVAP) Canister Purge Solenoid, Fuel Composition Sensor, Secondary Fuel Pump Relay
ETC/ECM Fuse
15A
Throttle Actuator Control (TAC)
INJ 1 Fuse (Gas)/ACTUATOR Fuse (Diesel) #2
15A
Fuel Injectors – Odd-Numbered, Ignition Coils – Odd-Numbered – Gas
15A
Engine Control Module (ECM) – Diesel
INJ 2 Fuse (Gas)/ECM Fuse (Diesel) #1
15A
Fuel Injectors – Even-Numbered, Ignition Coils – Even-Numbered – Gas
25A
IGN E Fuse
10A
A/C COMP Relay, Park/Neutral Position (PNP) Switch, Turn Signal/Multifunction Switch, Headlamp Leveling Components, Clutch Start Switch
IGN 1 Relay (Gas)/ECM Relay (Diesel) #5
SBA Fuse, ETC/ECM Fuse, PCM 1 Fuse, INJ 1 Fuse, INJ 2 Fuse
ACTUATOR Fuse, ECM Fuse – Diesel
RTD Fuse
30A
Not Used
TRL B/U Fuse
10A
Body Control Module (BCM), Trailer Wiring, Backup Alarm
PCM B Fuse (Gas)/ECM B Fuse (Diesel)
20A
Powertrain Control Module, F/PMP Relay – Gas
20A
Engine Control Module (ECM ) – Diesel
F/PMP Relay
Fuel Pump
O2 A Fuse (Gas)/FUEL HTR Fuse (Diesel) #3
15A
Heated Oxygen Sensors – Upstream – Gas
15A
Fuel Heater, Glow Plug Controller, Intake Air (IA) Heater Relay, EGR System Components – Diesel
B/U LP Fuse
20A
Park/Neutral Position (PNP) Switch – A/T, Backup Lamp Switch – M/T
RR DEFOG Fuse
30A
DEFOG Relay
HDLP – HI Relay
HI HDLP – LT Fuse, HI HDLP – RT Fuse
O2 B Fuse (Gas)/EMC 1 Fuse (Diesel) #4
15A
Heated Oxygen Sensors – Downstream – Gas
15A
MAF/IAT Sensor, Engine Control Module (ECM) – Diesel
AIRBAG Fuse
15A
Inflatable Restraint Sensing and Diagnostic Module (SDM), Memory Seat Module-Passenger, Inside Rearview Mirror
FRT PARK Fuse
10A
Park/Turn Signal Lamps – Front, Marker Lamps – Front
DRL Relay
DRL Lamp – LT, DRL Lamp – RT
SEO IGN Fuse
10A
DEFOG Relay, Instrument Panel Cluster (IPC) – (8S8), Selectable Ride Switch – ZX3
TBC IGN 1 Fuse
10A
HI HDLP–LT Fuse
10A
Headlamp – High Beam – Left
LH HID Fuse
20A
Not Used
DRL Fuse
10A
DRL Relay
RVC Fuse
10A
Generator Battery Control Module
IPC/DIC Fuse
10A
HVAC/ECAS Fuse
10A
HVAC Control Module
CIG LTR Fuse
15A
Cigar Lighter, Data Link Connector (DLC)
HI HDLP RT Fuse
10A
Highbeam Headlamp – Right
HDLP-LOW Relay
LO HDLP – LT Fuse, LO HDLP – RT Fuse
A/C COMP Relay
A/C COMP Fuse
10A
TCM B
10A
Transmission Control Module (TCM)
RR WPR
25A
Not Used
RADIO Fuse
15A
Radio, Rear Seat Audio (RSA), Digital Radio Receiver – U2K
SEO B1 Fuse
15A
Instrument Panel Cluster (IPC) – 8S8, Overhead Console, Roof Beacon Switch
LO HDLP–LT Fuse
10A
Headlamp – Low Beam – Left
BTSI Fuse
10A
Stop Lamp Switch
CRNK Fuse
10A
Powertrain Control Module (PCM) – Gas, Engine Control Module (ECM) – Diesel, Transmission Control Module (TCM) – MW7
LO HDLP–RT Fuse
10A
Headlamp – Low Beam – Right
FOG LP Relay
Fog Lamp – RF, Fog Lamp – LF
FOG LP Fuse
15A
FOG LP Relay
HORN Relay
HORN Fuse
W/S WASH Relay
Windshield Washer Fluid Pump
W/S WASH Fuse
15A
W/S WASH Relay
INFO Fuse
15A
Vehicle Communication Interface Module (VCIM) – UE1, Rear Seat Entertainment (RSE) Assembly – U42, Remote Playback Device – CD Playe r – U1S
RADIO AMP Fuse
30A
Audio Amplifier
RH HID Fuse
20A
Not Used
HORN Fuse
15A
Horn – Left, Horn – Right
EAP Fuse
15A
Not Used
TREC Fuse
30A
Transfer Case Encoder Motor, Transfer Case Shift Control Module
SBA Fuse
15A
Supplemental Brake Assist (SBA), Fuel Pump Relay – Secondary – w/o NQZ
  • OEM: 12193905
  • Service: 12193905
A1–A2
Not Used
A3
YE
5
Crank Voltage
A4
Not Used
A5
OG
4340
A6
PK
39
Ignition 1 Voltage
A7
YE
1139
Ignition 1 Voltage
YE
1139
A8
L-GN/BK
584
A9
PK
3
Ignition 1 Voltage
A10
Not Used
A11
D-GN
1433
A12
BN
2409
BN
2409
B1
OG
1640
B2
OG
2268
B3
D-GN/WH
1317
D-GN/WH
1317
B4–B7
Not Used
B8
OG
1840
B9
BK/WH
1969
B10
Not Used
B11
OG
3840
B12
RD
142
C1
OG
1640
C2
OG
3240
C3
BK
28
Horn Relay Control
BK
28
Horn Relay Control
C4–C5
Not Used
C6–C7
Not Available
C8
Not Used
C9
PK
1020
Ignition 0 Voltage
C10
OG
1040
C11
Not Used
C12
PU
420
D1–D2
Not Used
D3
PK/WH
1970
D4
OG
340
OG
340
D5
OG
640
OG
640
D6–D7
Not Available
D8–D9
Not Used
D10
PK
639
Ignition 1 Voltage
D11
Not Used
D12
OG
1140
E1–E2
Not Used
E3
L-GN /BK
592
DRL Relay Control
E4
OG
4540
OG
4540
E5
Not Used
E6
BN/WH
1571
E7
L-BU
1320
E8
Not Used
E9
D-GN
591
E10
D-BU
2115
E11
OG
2340
E12
Not Used
F1
PK
139
F2
OG
3740
F3
L-BU
2114
F4
Not Used
F5
PK
739
PK
739
Ignition 1 Voltage
F6
PK
639
PK
639
F7
OG
2840
F8–F9
Not Used
F10
GY
1524
L-GN
24
L-GN
24
F11
WH
1080
F12
OG
1540
  • OEM: 12193906
  • Service: 12193906
A1–A2
Not Used
A3
D-GN
59
A4–A6
Not Used
A7
D-GN/WH
465
A8
Not Used
A9
PK
1339
Ignition 1 Voltage
A10
L-BU
1320
A11
GY
1524
GY
1524
A12
PK
439
PK
439
B1
Not Used
B2
OG
3440
B3
BK/WH
1695
Axle Switch Signal
BK/WH
1695
Axle Switch Signal
B4–B6
Not Used
B7
BK
550
Ground
B8
OG
440
OG
440
B9
PK
1039
Ignition 1 Voltage
PK
1039
B10
PK
439
PK
439
B11–B12
Not Used
C1–C2
Not Used
C3
D-GN/WH
459
C4–C5
Not Used
C6–C7
Not Available
C8–C9
Not Used
C10
PK
1039
PK
1039
C11
Not Used
C12
PU
420
PU
420
D1–D2
Not Used
D3
L-GN
275
D4
Not Used
D5
RD/WH
4740
RD/WH
4740
D6–D7
Not Available
D8
PK
539
PK
539
PK
239
PK
239
D9
PK
1239
PK
339
PK
339
D10
PK
1039
PK
1039
D11
PU
6
D12
YE/BK
625
E1–E5
Not Used
E6
PK
1239
PK
1239
GY/BK
2219
E7
PK
1539
PK
1539
PK
439
PK
439
E8–E9
Not Used
E10
PK
1239
PK
1239
E11
PK
1020
PK
1020
Ignition 0 Voltage
E12
Not Used
F1–F2
Not Used
F3
PU
806
Crank Voltage
PU
806
Crank Voltage (MW7)
F4
OG
4440
OG
4440
F5–F7
Not Used
F8
PK
839
Ignition 1 Voltage
F9
PK
639
F10
PK
1020
Ignition 0 Voltage
PK
1020
F11
D-GN
1433
BK
550
PK
639
F12
Not Used
  • OEM: 12193916
  • Service: 12193916
A1–A2
Not Used
A3
D-BU
2115
A4
OG
2640
A5
PU
420
A6
Not Used
B1
BK/WH
1695
B2
Not Used
B3
L-BU
2114
B4–B5
Not Used
B6
BN
2109
C1
Not Used
C2
L-GN
1624
L-GN
1624
C3–C4
Not Available
C5
Not Used
C6
BN/WH
2609
D1–D2
Not Used
D3–D4
Not Available
D5–D6
Not Used
E1–E3
Not Used
E4
BK
550
Ground
E5–E6
Not Used
F1
GY
120
GY
120
F2–F3
Not Used
F4
L-BU
1320
F5
Not Used
F6
BN
2509
  • OEM: 12193914
  • Service: 12193914
A1–A2
Not Used
A3
D-BU
2115
D-BU
2115
A4
BK
550
Ground
BK
550
Ground
A5
Not Used
A6
D-GN
1329
D-GN
1329
B1
Not Used
B2
D-BU
545
D-BU
545
B3–B6
Not Used
C1
BN
2309
BN
2309
C2
Not Used
C3–C4
Not Available
C5
BN
2309
BN
2309
C6
RD
228
D1–D2
Not Used
D3–D4
Not Available
D5
Not Used
D6
PU
34
PU
34
E1
L-BU
2114
L-BU
2114
E2
D-GN/WH
711
E3
L-GN/BK
311
E4–E6
Not Used
F1–F3
Not Used
F4
YE
712
F5
TN/WH
312
F6
Not Used
  • OEM: 15393171
  • Service: 88986444
A
RD
842
B
RD
542
  • OEM: 15393172
  • Service: 88986445
  • Description:
A
RD
642
B
Not Used
  • OEM: 15393168
  • Service: 88986443
A
RD
342
RD
342
B
RD
42
  • OEM: 15393170
  • Service: 88986446
  • Description: 2-Way F J-Type (NA)
A
RD
442
B
Not Used
At your convenience, I would like to see wiring between the door lock/unlock PCB relay in the fuse block to the driver's door switch (both inclusive) for my 2008 LMM crew cab with RPO AU3 door locks. Those are the most simple door lock switches, just open/close, one of the driver front door, one on the passenger front door. My door locks function just fine with the key, and the key fob, just not the switch on either door. Fuses have no power. i have looked in GMUPFITTER but just don't see what I need there.
Very nice of you to furnish wiring diagrams. I appreciate that.
61 - 80 of 93 Posts
