141 - 160 of 328 Posts
If you guys need any diagrams let me know. Anything from 2001 to 2019 trucks just be specific on what you need.
I will ignore any post that wants every single diagram of their car. If you have a specific Electrical issue let me know. 2001 - 2007.5 are mostly the same.
Do not use me as your first source for diagrams, I'm very unreliable, and lazy. :(
Template:
GMC/Chevy GM use to switch wire colors until 2007.5
Year:
Model:
Picture of RPO codes in glove box.
Picture of harness with color wires.
Diagrams needed.
I need wiring diagram for abs module harness for 2008 silverado crew cab LT Texas edition 5.3 V8. Can you help?
Template:
Year:
Model:
Diagrams needed.
Any idea what this is? Was plugged into a harness coming off EDU on a LB7 duramax. The other end was just hanging their. Thanks.
Discussion starter · #144 ·
Could I get ground points for the maf on a 2009 lmm. Thanks
Mass Air Flow (MAF)/Intake Air Temperature (IAT) Sensor (Diesel)
Connector Part Information
  • OEM Connector: 15443141
  • Service Connector: 19151506
  • Description: 5-Way F TS Series Sealed (BK)
Terminal Part Information
  • Pins: 1–5 (Early Production)
  • Terminal/Tray: 8100-3455/22
  • Core/Insulation Crimp: 8/8
  • Release Tool/Test Probe: 15315247/J-35616-64B (L-BU)
  • Pins: 1–5 (Late Production)
  • Terminal/Tray: 8100-3456/26
  • Core/Insulation Crimp: K/K
PinWireCircuitFunction
10.5 YE492MAF Sensor Signal
20.5 GY/BK2931Low Reference
30.5 PK1839Ignition 1 Voltage
40.5 TN2760Low Reference
50.5 TN/BK472IAT Sensor 1 Signal
Template:
Year:
Model:
Diagrams needed.
I have a 2015 duramax LML i need a diagram of the engine harness and the ECM pinout. Please and Thank you.
Thank you
Template:
Year:
Model:
Diagrams needed.
Hi and thanks that you are doing this.
i need the whole colored wire diagrams for 2011-LML T-case. From Dash Switch, t-case controller and t-case motor.
Something like this, this schematic is wrong year, but the switch and box is correct year.
Thanks
Discussion starter · #149 ·
i need the whole colored wire diagrams for 2011-LML T-case. From Dash Switch, t-case controller and t-case motor. View attachment 1099608 View attachment 1099609
Thanks
RPO CODE?!?! GLOVE BOX!!!
Each have their own wiring diagram. Therefore I can't give you whatever.
RPO NQG, 1222/1225/1226
RPO NQF, 1625/1626
RPO NQH, 3023/3024
RPO NQF, 1625/1626
RPO NQH, 3023/3024
I have only the T-case, dash switch, controller box and wire harness, everything is bought here and there. Its for a swap, so I don’t have the donor truck. But I know it’s MP1626XHD T-case NQF from a 2011 LML 2500HD Truck.
Thanks if you can help
Discussion starter · #152 ·
Been busy I'll get to you when I can.
Discussion starter · #154 ·
Wiring diagrams are posted separately.
Transfer Case 2/4 Wheel Drive Actuator Position Sensor (NQH)
  • Harness: Engine
  • OEM: 15326808
  • Service: 15306388
  • Description: 3-Way F GT 150 Sealed 4.5 (BK)
  • Terminated Lead: 13327112
  • Release Tool: J-38125-553
  • Diagnostic Test Probe: J-35616-2A (GY)
  • Terminal/Tray: 12191819/8
  • Core/Insulation Crimp: E/1
A0.5 YE/BK7478Low Reference
B0.5 OG/WH74775-Volt Reference
C0.5 L-GN7479Rotary Position Sensor Signal
Transfer Case Encoder Motor (NQF or NQH)
  • Harness: Engine (Gas)
  • Harness: Engine Chassis (Diesel)
  • OEM: 15326654
  • Service: 88986254
  • Description: 8-Way F GT 280 Sealed 5.8 (L-GY)
  • Terminated Lead: Service by Connector Assembly - 88986254
  • Release Tool: Not Available
  • Diagnostic Test Probe: Not Available
  • Terminal/Tray: Not Available
  • Core/Insulation Crimp: Not Available
A3 TN1552Motor Control A
B3 RD/BK1342Battery Positive Voltage (NQH)
C2 TN1569Lock Solenoid Control (NQH)
D3 OG1553Motor Control B
E0.35 D-BU/WH7473Incremental Encoder Impulse Signal (except NQH with LU3)
0.35 L-GN/D-BU7473Incremental Encoder Impulse Signal (NQH with LU3)
F0.35 YE7474Incremental Encoder Direction Signal
G0.35 WH/L-GN7475Incremental Encoder Sensor (8V) Supply
H0.35 PU7476Low Reference
Transfer Case Shift Control Module X1 (NQF or NQH)
  • Harness Type: Instrument Panel
  • OEM Connector: 13520383
  • Service Connector: 13577630
  • Description: 16-Way F 150 GT FBT Series (GY)
  • Pins: 2–3, 5–6, 9–15
  • Terminated Lead: 13575481
  • Release Tool: J-38125-29
  • Pins: 4, 7
  • Terminated Lead: 13575480
1——Not Used
20.35 GY60295-Volt Reference
30.35 D-BU/WH7473Incremental Encoder Impulse Signal
40.5 OG/WH74775-Volt Reference (NQH)
50.35 BN1560Neutral Indicator Control
60.35 L-GN/BK15632 HI Indicator Control
71 TN1569Lock Solenoid Control (NQH)
8——Not Used
90.35 WH/L-GN7475Incremental Encoder Sensor (8V) Supply
100.35 PU7476Low Reference
110.35 L-BU1693Switch Signal
120.35 TN/BK15664 HI Indicator Control
130.35 PU/WH15654 LO Indicator Control
140.35 PK1561AWD Indicator Control (NQH)
150.35 GY/BK1570Axle Actuator – Control
16——Not Used
Transfer Case Shift Control Module X2 (NQF or NQH)
  • OEM Connector: 13547238
  • Service Connector: 88988779
  • Description: 16-Way F 1.5 Series (BN)
  • Terminated Lead: 13575790
  • Terminal/Tray: 8240-0127/22
  • Core/Insulation Crimp: E/C
1–2——Not Used
30.5 TN/WH1695Axle Switch Signal
40.5 TN2501High Speed GMLAN Serial Data Bus (-)
50.5 TN/BK2500High Speed GMLAN Serial Data Bus (+)
60.35 PK239Ignition 1 Voltage
7–8——Not Used
90.5 YE/BK7478Low Reference (NQH)
100.5 D-BU5985Accessory Wakeup Serial Data
110.5 L-GN7479Rotary Position Sensor Signal (NQH)
120.5 TN2501High Speed GMLAN Serial Data Bus (-)
130.5 TN/BK2500High Speed GMLAN Serial Data Bus (+)
140.35 YE7474Incremental Encoder Direction Signal
15–16——Not Used
Transfer Case Shift Control Module X3 (NQF or NQH)
  • OEM Connector: 15466671
  • Service Connector: 19149301
  • Description: 4-Way F GT 280 Series (L-GY)
  • Terminated Lead: 13575756
  • Diagnostic Test Probe: J-35616-4A (PU)
  • Terminal/Tray: 15304713/19
  • Core/Insulation Crimp: F/D
A3 OG1553Motor Control B
B3 TN1552Motor Control A
C3 RD/BK1342Battery Positive Voltage
D3 BK550Ground
Transfer Case Shift Control Switch (NQF or NQH)
  • OEM Connector: 13587624
  • Service Connector: 19151154
  • Description: 12-Way F 64 Series, Sealed (GY)
  • Terminated Lead: 13575845
  • Release Tool: J-38125-215A
  • Diagnostic Test Probe: J-35616-64B (L-BU)
  • Terminal/Tray: Not Available/
  • Core/Insulation Crimp: P/P
1——Not Used
20.35 WH2283Ignition 1 Voltage
30.35 BN1560Neutral Indicator Control
40.35 PU/WH6816Indicator Dimming Control
50.5 BN/WH230Instrument Panel Lamps Dimming Control
60.5 BK1050Ground
70.35 L-GN/BK15632 HI Indicator Control (NQF)
80.35 L-GN/BK15632 HI Indicator Control (NQH)
90.35 TN/BK15664 HI Indicator Control
100.35 PU/WH15654 LO Indicator Control
110.35 GY60295-Volt Reference
120.35 L-BU1693Switch Signal
[/QUOTE]
Discussion starter · #158 ·
Can I ask what you must do for having access to all of this information? I’ve tried Alldata, but since I am in Europe they won’t let me access US trucks. Thanks
Mitchell 1: Pro-demand
identifix
I don't use color wiring diagrams anymore, since they give me the run around at times.
I was in school, so pro-demand and alldata were free to use. I don't recommend pro demand it's very ugly and old but it has what you need I can't say the same for identifix.
identifix
Thanks again! Good info! I will check it out, hope I can get access at this🤞🏻
Template:
Year:
Model:
Diagrams needed.
