1 - 9 of 9 Posts
At what time is is nesary to do injector's? + Head gaskets and head studs fire rings? I would like every bodys options on this?
Discussion Starter · #2 ·
This would probly be done after lift pump,trans.
injectors and studs would be about the same time as you add a bigger turbo(s)
but after a lift pump and trans like you said.
I was under the assumption that fueling upgrades to the dmax like injectors/cp3 were borderline dangerous on stock bottom ends? I thought that the pistons/rods were in danger before the headgaskets, just what i've been told.........
Haven't heard that yet. This is news to me.
im getting ready to have my injectors done over 40% i run and air dog 125 with it and it does good but the next mod for me is an ats turbo so i just decided more boost+stock injectors= not enough black smoke :(
I looked at the nozzles from Dynamite diesel. Is their anyone else that sells injectors and or nozzles?
I suggest a different turbo than a ATS for your LMM. I would look into a HTT66 or Garrett 4094vvt, or twins.
If you have any questions let me know.
Tyler
MPF
1 - 9 of 9 Posts
