Hmmm, I got the same truck too, I'm running a 6" lift, 35" tires and I just added the MBRP 4" duals from the down pipe back, and added a cold air intake and I only get 13 MPG empty with mixed hwy and city driving, and I do not hammer it, I try to keep the tack at 1800 or 1900 on the hwy so thats around 115 KPH. The sad thing is this truck has an EFI Live tune from about 3 years ago from the original owner, but its going back in for the EGR Delete and maybe an upgraded tune to try and improve it.I have the same truck and the edge will give you better milage with it in 5 or 6 with the cruse set just don't beat on it! EFI LIVE changed my milage greatly I get 18-19 on the freeway and I have 35s
A lift changes alot, now your playing with aerodynamics and a lift doesn't work in your favor, 35's aren't helping either, 13's a tad low but for a mix of city and freeway it far off, but with a new tune optimized for your setup you might get a tad better but don't expect to much, dont trust the DIC, hand calculate it if you already aren'tHmmm, I got the same truck too, I'm running a 6" lift, 35" tires and I just added the MBRP 4" duals from the down pipe back, and added a cold air intake and I only get 13 MPG empty with mixed hwy and city driving, and I do not hammer it, I try to keep the tack at 1800 or 1900 on the hwy so thats around 115 KPH. The sad thing is this truck has an EFI Live tune from about 3 years ago from the original owner, but its going back in for the EGR Delete and maybe an upgraded tune to try and improve it.
Thanks, I know the lift and tires are working against me, but I figured a diesel would get better mileage than my 08 F150 got LOL. The mileage wasnt really any better before the lift, if it was at all better, it wasnt enough to really notice it at all haha. And ya, I calculated it myself, and I added the miles that the larger tires didnt get accounted for on the trip meter. The DIC says I'm at around 19 mpg, but by hand calculations I am at just a hair over 13 MPG.A lift changes alot, now your playing with aerodynamics and a lift doesn't work in your favor, 35's aren't helping either, 13's a tad low but for a mix of city and freeway it far off, but with a new tune optimized for your setup you might get a tad better but don't expect to much, dont trust the DIC, hand calculate it if you already aren't
Well i dont use kilometers but it sounds like you have an error in there somewhere, go to the dealer or when you get your truck tuned make sure to get your speedo corrected... How are you calculating it? the easiest is to fill ALL the way up, reset the trip, run it down and fill it ALL the way back up and divide the gallons by the miles. Are you trying to account for the whole tank?Thanks, I know the lift and tires are working against me, but I figured a diesel would get better mileage than my 08 F150 got LOL. The mileage wasnt really any better before the lift, if it was at all better, it wasnt enough to really notice it at all haha. And ya, I calculated it myself, and I added the miles that the larger tires didnt get accounted for on the trip meter. The DIC says I'm at around 19 mpg, but by hand calculations I am at just a hair over 13 MPG.
And the error with the tires in the speedo is about 6% if I figured it right, 100 KPH on my speedo is around 106 on my GPS, so 450 KM/tank is really about 477 KM/tank and with an 85 liter tank, it works out to around 13 mpg.....right?
wow thats too bad mine got 14 mpg with the lift and tires before any mods lol so you might wanna get that checked out after everything about 18mpg calculated and if your going off the dash reading and your speedo isn't recalibrated thats way off because your trucks not going as far as it thinks. you have to take your miles by the gallons to figure it out right!Hmmm, I got the same truck too, I'm running a 6" lift, 35" tires and I just added the MBRP 4" duals from the down pipe back, and added a cold air intake and I only get 13 MPG empty with mixed hwy and city driving, and I do not hammer it, I try to keep the tack at 1800 or 1900 on the hwy so thats around 115 KPH. The sad thing is this truck has an EFI Live tune from about 3 years ago from the original owner, but its going back in for the EGR Delete and maybe an upgraded tune to try and improve it.
Ya, I converted the liters to gallons and the kilometers to miles and I reset the trip on every fill up and run it till the low fuel message comes on. At that point I fill up and the 85 liter tank usually takes about 82 liters to fill it. I resent the trip and do it all over again, every single fill up.Well i dont use kilometers but it sounds like you have an error in there somewhere, go to the dealer or when you get your truck tuned make sure to get your speedo corrected... How are you calculating it? the easiest is to fill ALL the way up, reset the trip, run it down and fill it ALL the way back up and divide the gallons by the miles. Are you trying to account for the whole tank?
