I'm looking at getting new tires but I need to get my front end fixed so my tires don't wear as bad as this one did. The pic is of my front passenger side tire the whole outside of the tire is worn badly and the inside is barely worn. What would cause this? My drivers side was worn pretty evenly. I've got a pretty bad bump steer and I replaced the idler n pitman arms, upper ball joints and outer tie rods last spring. Could my lower ball joints be causing this? Thanks
A worn ball joint could cause this.
Could need a front end alignment camber/caster could be out've spec. If a ball joint was that bad you should be able to hear it "thumping" when you hit bumps.
