1 - 2 of 2 Posts
So this sat. I decided to finally relocate my ccv tube so I didnt have oil being sucked back into my turbocharger. Not sure now if this was a grand idea. After I made up something using ppe ccv fittings and some hose I started it up and it ran good. For about 15 or so b4 i shut it down. The next morning i started up and almost immediately notice the check engine light came on. Ran the code p2565 I believe. Having to do with the vane position sensor. That was the only wire I moved around a bit to make my new lines fit. So I cleared the code started again for 15 min no light. But when I started it this afternoon again the light came on with the same code. I have been told these parts fail prematurely but seeing how this is the only wire I physically touched I'm almost wondering if I haven't cracked or shorted the inside wires out. Anyone have similar problems or had this happen after moving the wire. The wire isnt bare or being grounded either
DTC P2564 or P2565
Diagnostic Instructions
DTC Descriptors
DTC P2564
  • Turbocharger Boost Control Position Sensor Circuit Low Voltage
DTC P2565
  • Turbocharger Boost Control Position Sensor Circuit High Voltage
Diagnostic Fault Information
Typical Scan Tool Data
Circuit/System Description
The position of the turbocharger vanes is controlled by the engine control module (ECM). The ECM commands the TC vane position solenoid to change the position of vanes in order to vary boost depending upon the load requirements of the engine. The TC vane position sensor provides the ECM with a signal voltage relative to position of the turbocharger vanes.
Conditions for Running the DTC
P2564
  • The engine has been running for more than 3 seconds.
  • DTC P2564 and P2565 run continuously when the above conditions are met.
P2565
Conditions for Setting the DTC
P2564
The ECM detects that the turbocharger vane position sensor voltage is less than 0.28 volt for greater than 1 second.
P2565
The ECM detects that the turbocharger vane position sensor signal voltage is greater than 4.7 volts for greater than 1 second.
Action Taken When the DTC Sets
DTCs P2564 and P2565 are Type B DTCs.
Conditions for Clearing the MIL/DTC
Circuit/System Verification
  1. Verify that DTCs P0698 or P0699 are not set.
  • If any of the DTCs are set, refer to DTC P0698 or P0699. See: P0698
  1. Engine running, observe the scan tool TC Vane Position Sensor and the Desired Vane Position parameters while slowly increasing the engine speed to 2,500 RPM, then returning the engine speed to idle. The TC Vane Position Sensor parameter should remain near or equal to the Desired Vane Position parameter.
  2. Operate the vehicle within the Conditions for Running the DTC. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records data.
Circuit/System Testing
  1. Ignition OFF, disconnect the harness connector at the TC vane position sensor.
  2. Ignition OFF for 90 seconds, test for less than 5 ohms between the low reference terminal C and ground.
  • If greater than the specified range, test the low reference circuit for an open/high resistance. If the circuit tests normal, replace the ECM.
  1. Ignition ON, test for 4.8-5.2 volts between the 5-volt reference circuit terminal D and ground.
  • If less than the specified range, test the 5-volt reference circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the ECM.
  • If greater than the specified range, test the 5-volt reference circuit for a short to voltage. If the circuit tests normal, replace the ECM.
  1. Verify the scan tool TC Vane Position Sensor parameter is less than 2 percent.
  • If greater than the specified range, test the signal circuit terminal B for a short to voltage. If the circuit tests normal, replace the ECM.
  1. Install a 3A fused jumper wire between the signal circuit terminal B and the 5-volt reference circuit terminal D. Verify the scan tool TC Vane Position Sensor parameter is greater than 98 percent.
  • If less than the specified range, test the signal circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the ECM.
  1. If all circuits test normal, test the TC vane position sensor.
Component Testing
Important:
You must perform the Circuit/System Testing in order to verify the integrity of the TC vane position sensor circuits before proceeding with Component Testing.
Erratic Signal Test
  2. Remove the TC vane position sensor.
  3. Connect the TC vane position sensor harness connector.
  4. Ignition ON, observe the scan tool TC Vane Position Sensor parameter while slowly depressing the button at the end of the sensor. There should be a smooth percentage change without any spikes or drop-outs.
If the TC Vane Position parameter does not increment smoothly or is erratic, replace the TC vane position sensor.
Repair Instructions
  • Turbocharger Vane Position Sensor Replacement
Repair Verification
Engine running, observe the scan tool TC Vane Position Sensor and the Desired Vane Position parameters while slowly increasing the engine speed to 2,500 RPM, then returning the engine speed to idle. The TC Vane Position Sensor parameter should remain within 2 percent of the Desired Vane Position parameter.
1 - 2 of 2 Posts
