121 - 128 of 128 Posts
Discussion Starter #122
Installed all new Bosch Injectors trying to chase a idling problem... Worked fine for about 2 hrs now its back. Back to then drawing board, truck did run phenomenal with new injectors though! Currently sitting at 246,130 miles.
How long did it take to change all 8?
Sent from my SM-G950U using Tapatalk
Discussion Starter #124
he had it done in about 4 hours and that included changing tensioners and a new belt.
Fixed my #5 cylinder misfire. Ended up being a loose pin in the ECM plug.
Does each cylinder have a pin in the ECM?
Discussion Starter #128
Factory filter head deleted, also swapped the lower radiator hose oring with a new one. Finally getting to enjoy these new injectors.
246,286k on the clock
