I like the look of both tires and going with 285 no matter what tire i get next. I tow 10k loads almost once or twice a week during the summer. The Gerneral grabber at2 285 tire is a D rated tire, so max psi is 65, while the KO is E and 80 psi? First off, how many of you guys actually run 80psi when you tow? is there much difference between 65 and 80PSI? I know it will ride ruffer, but if it really helps for towing i'd be ok with it. the 265 general grabbert at2 is E rated, which is just a slightly smaller tire. Could i run the 285 at2 at 70-75 PSI and be ok? Will running 75-80 PSI help with tire wear? thanks
