Black Smoke on moderate acceleration and it is not a central problem common to all cylinders like a boost issue or air restriction. Using snap-on scanner I cancelled off each injector 1 through 8 and found smoking stoped completly when cylinder 1 was dissabled. Replaced injector with new one from dealer and same problem no change. Suspected bad injector from dealer so swaped injector #1 with #2 and still smoking on cyinder #1.
Performed compression check on right bank and even readings across the board aprox 450 psi.
:helpAnyone see this before?
2005 lly completly stock
