blower motor runs after truck and unit are off
2.6K views 5 replies 4 participants last post by  BigDumbDually
my blower motor runs after i shut down the vent control.. 03 diesel..the stupid digital dual zone setup..i can only shut it down by pulling the relay from under the hood....any ideas?:help
#4 ·
I think that DuramaxBoy is right. They updated those resistores in 04 or 05 and they are common for shorting out. Easy to change under glove box.
it shuts off when the relay is removed...i tried a new relay and there was no change, it still runs when the truck is off....i took apart the dash and removed the climate control, un-plugged the two rear wire plugs, and the blower still runs....is there a vac operated switch? when i removed the blower fuse and the ac fuse from the panel inside the truck the blower still runs with no fuse...only shuts when relay is pulled...any ideas?
