Anyone used it I seen one cant find it now or even remember what it was called. I seen the adapter on ebay from metapark for like 15bucks. Just curious if it would be worth it or not.
Read Only
Got my adapter working today. I bought the TorquePro App for my Android phone and I am shocked that I an do a ton of stuff wirelessly thru the BlueTooth adapter conencted to my ODB II port. For $25 + 4.95 for the app (and yes there are free versions) I can see a ton of stuff that other display do for hundreds. You gotta cehck it out....
yeah I have the same app. You can get it on 4shared.com for free.
But I use it all the time to clear codes on friends cars and trucks. Just used it this morning actually. My cars O2 sensor is going bad and I was tried of seeing the CEL on.
You can monitor a lot. Just depends on what your ECM will send to it. Mine shows RPM, alot of little readings for MAF and Boost.
My main menu I have RPM, Speed, Coolant temp, Accel, Throttle and boost.
Also, it will record your route through google maps. Its a nice, cheap little code reader and real time data viewer.
