My truck often dies when I hit even a small bump.
i’ve been working through lots of potential fixes.
I have removed, cleaned and put dielectric grease on the two grounds on the front of the truck body near the suspension, then the two below the front door pillars and the two on the dash under the windshield.
I have replace the brake pedal switch.
I have replaced the trailer brake controller which fixed the trailer brake alarms.
After cleaning the grounds, I went almost two weeks after cleaning the ground with little to no issues. Then they came back.
yesterday it started doing it as I left work. I found that if I wedged my boot under the brake pedal pushing it upwards fairly hard, I had no more issues all the way home (45 miles). I got a bungy cord and hooked it to the brake pedal and up to the dash tightly trying to simulate the boot pressure. All the way to work this morning and all the way home, then it died once.
It seems clear to me that there are multiple issues going on, or at least the issue is manifesting itself in multiple ways.
The only codes I get refer to the headlights, tail lights, and license plate light circuits and my scanner mentions the BCM. I need to work through what might be causing the codes to pop and determine whether the codes are directly related to the engine dying, but this is got me thinking about the BCM.
Up until the boot and bungi cord thing, it was very intermittent. Sometimes I would go for days with no issue, then have it happen five times in a few miles.
I’ll take any advise anyone is willing to provide.
