My 2003 chevy duramax 4x4 started pulling to the center lane during braking so i replaced the front right caliper that seemed to correct the problem for awhile then it began to do the same with a vibration and some drag in the front so i replaced the rotors along with the brake pads on both sides, after i put it all back together i noticed alot of drag in the front passenger tire so i thought it might have been the wheel bearing all along so i pulled it back apart and replaced it to, that allowed the tire to spin free untill i put the caliper back on then it gets alot of drag back. I went ahead a gave it a test drive and everything works well with the exception that the front passenger rotor is smoking hot do you guys think the new caliper is got a problem or any other suggestions?:help
