I have an 06 LLY 2500HD deleted 265,000 miles.
First off started to find a bunch of leaks in the lines like the power steering and trans cooler lines of that nature so decided to replace them with OEM. Also the power steering pump started to leak like a waterfall so got the upgraded 12 spline ACDelco power steering pump (20756713). The steering was super tight and had an extra PS Gearbox and not sure if it was a reman or not but installed it. (Came with the truck when I purchased it). Next the hydroboost and master cylinder had a good leak as well. Replaced the hydroboost with the ACDelco 2011 upgraded version (178-1036) after I drilled out the peddle rod to 17mm then the master with ACDelco (18M2426).
Now my brakes are locking up.
Backstory
I bench bled the master accidentally with power steering fluid. A day later I realized what I had done and flushed it out and put brake fluid in it and bench bled it again. I also put ACDelco brand power steering fluid and brake fluid in my system for best results.
so after reading many forms about the push rod being too long on the hydroboost I added 2 #10 washers on each side between the master and hydro. Seemed to be great until the front was just locking up. Added 2 more washers between it and i was like finally fixed! After some aggressive braking and steering of about 40 minutes everything was perfect.
I kid you not, the next day I hook up the trailer and some casual driving and things heated up the front brakes were catching… It’s almost like the brake pedal does not have any play when it does this and the steering becomes extremely difficult and pulsates. I took the ABS fuse out and eliminated that factor. But once it has been running for 20min and the fluids get hot it’s almost like the fluid is expanding the hydroboost not letting it retract or there’s not enough pressure pushing back on the master. Once they lock up I can crack the bleeder screw and fluid shoots out about 3-4ft relaxing the system until another 5 minutes.
Any advise would be much appreciated!
Backstory
