1 - 20 of 27 Posts
Banned
I am having a problem with breaking wheel studs on my left front wheel since I put new wheels on my truck. I put new wheels on and took them off and broke 2 studs. Put the wheel on got the studs and went to put them on then broke 3 more taking the wheel off :mad:
IDK what the deal is. My buddy has a theory that racing or lauching in 4wd cause the studs to bend possibly with a loose wheel or something. Then they finally breaking now. Anyone else here of this?
With your front wheels off the ground, is there any travel rocking it to and from you? My first guess would be hub assemblies. First thing I did after getting my beast home a few weeks ago was put Timken front hub assemblies on. Even at only 50k, the stock ones had about a millimeter of travel. That would be more than enough in a hard 4WD launch situation to damage studs. Those hubs aren't supposed to move at all.
Banned
I work at a garage and did check it up in th air. It seems good. Mine only has 30,000 miles on it :cool:
oldschool
are you over torquing them?
should be around 110 ft lb
Banned
oldschool
if its a problem I would use the torque wrench to tighten down new studs, if the older ones a over torqued there junk
if you over stretch them they become brittle
Banned
Ya thats what I hear... The old ones almost look bent though. I just dont get it. My dad owns a auto repair shop for 15 years. It stumped him to :rolleyes:
are your lugnuts long enough? if they get tight but dont hold the wheel tight I guess that could cause your problem...dont know though
Banned
Ya there long enough. I took the rotor off and they nearly touch the hub without the bottoming off.
I went to 3 dealerships today to get 4 studs. I took the wheel of and broke one. Now I only have 1 original stud. Im gonna see how it works :cool:
Banned
Banned
Discussion Starter · #14 ·
Thats probably why your breaking them lol. 60k on mine and I havent broken a stud using a TQ wrench.
No theres definatly something up. My dad owns a garage with 10 technicians. It has him stumped. :rolleyes:
I know one thing...my lugs are never going on at 140ft lbs, even though that is what GM recommends. I broke several studs on my old Avalanche (also recommended @ 140ft lbs). I tried a Snap-on torque wrench, a Craftsman torque wrench and a Mountain torque wrench. All of them started getting easy around 130 and then POP! I have to say that the Dorman studs I put in place seemed a lot stronger, but the lugs went on at 100ft lbs, no more. Never had any more issues whatsoever. In my experience, 140ft lbs is way too much for a light duty truck. Maybe something like a Kodiak or F-450+.
i also had 2 studs break last week when i put the new wheels/tires on, also i will not follow gm tq specs 140 is Way to much!
i remember my neighbor saying he broke 16 a couple of summers ago because he was following the 140 tq spec.
I would just put some anti seize on the bolt's! Talk to a tire place, most of them I delivered to were buying studs all day long. The studs that come stock on GM vehicles are almost TQ to yield, they are so soft. Dorman bolts are better, but I have seen some that were a little harder, like the ones that come in the wheel lock kits do even better.
1 - 20 of 27 Posts
