1 - 2 of 2 Posts
:help
So .. . As I was inspecting my fuel lines I noticed a return line leaking. The passenger's side return line feeds into a block just under the main fuel supply line. It was leaking, so as I attempted to remove it I broke the return line fitting on the #2 injector. Then, after I removed the retention spring I rotated and tried to pull the fitting straight out, but broke it off. How do I get that piece of plastic fitting out of the injector? any ideas?
thank you
Heyyaa
I use a screw- just press it into the token part, and if the clip is off, it should come out ok.
1 - 2 of 2 Posts
