Finally installed the Amsoil Bypass system (thanks mrmanners) At first there did not seem like there was a lot of room but there is plenty. Took longer to decide where to put it than do the job. I drilled up either side of the supporting member directly under the heel of the accelerator foot. Popped up the carpet and dropped the bolts thru with goop on them to seal them up. Nuts on up to the underbelly sealed again for stability. Put another set of "adjustment" nuts/washers on then the bypass body so that I could "clamp" the body between them and the nylock nuts. As the heads were on top I could adjust the adjustment nuts to raise or lower the body to ensure clearance at the bottom of the bolts for the filters. The hydraulic hose was less than a foot each side. 13 quarts filled her to the top.
