1 - 7 of 7 Posts
I bought a set of smoked recon cab lights for my truck. I do not have factory cab lights. All three of the lights have a connector on the end of the wire. Do i just cut the connector off and run my own wire? Is there any kind of cab light wiring harness? Also where is a good place to wire them into so that when i have my headlight covers on, i can shut off the lights and the cab lights will be off too. All help is appreciated. Thanks
15846970 is the part number for the factory harness..
If i were you I would purchase this and then wire them into that harness, then just run the harness down the passenger side pillar and plug that sucker in :thumb
Where does it plug in to?
Passenger side fuse panel located on the side of the dash
Just tap into a fuse or is there a connector that i can plug into?
There's a connector that plugs straight in, let me see if i can find a writeup for ya
1 - 7 of 7 Posts
