a year ago I had the left wheel bearing aggressively go out and I changed it on the side of the road. Ever since then I’ve had a dangerously dramatic brake pull normally to the right but at one point it seemed like it seemed like it went whichever way the road leaned. It’s only pulled right for the last 3 months but I’ve been trying to use the exhaust brake and as little pedal as possible because it’ll put me in another lane. I’ve replaced wheel/hub assemblies, calipers, cv axles, sway bar links, and brake hose’s on both fronts and all rotors and pads. Each time I replace something it goes away for a couple hundred miles then comes back. I’ve had it at the shop twice and no ones figured it out
