1 - 12 of 12 Posts
So the answer to that question seems to be yes/maybe and no.
Yes, DEF can crystallize in the tank if it is low and left sitting. Will this cause you problems? Well if you listen to some of the hyperbole on the topic one would be left to freak out. I have learned that if something doesn't smell right on social media, you might need to check it out further. So that is what I have done on this topic.
First, it goes without saying that if you have your DEF tank low and crystals form, and then you add DEF to that tank, you now have added more urea to the new DEF from the old crystals dissolving, so you could be out of spec high with urea. That can be a problem and you may throw a code. So that is one problem that is very possible. I personally haven't heard or read this happening, but basic chemistry says it could happen.
Second, I have repeatedly read that once DEF has turned to crystalline form, it won't re-dissolve when contacted with liquid DEF. This has always set my BS alarm off, as it is outside what the norm would be with other crystalline substances that start out in a solution. So, I decided to do an experiment to see if I was wrong or if it truly is BS.
Below are some pics I took during the experiment. The narrative for the picture is under the picture.
1089944
These are two pans that I had in the garage. They were cleaned first with isopropyl alcohol and then washed with Dawn detergent and well rinsed and dried. I then added 6 ounces of Blue DEF to each pan. This was a new box of DEF with a date that indicated it was manufactured on July 2 2021. The pans were allowed to dry. This were the pans after 12 hours of drying, there is still a little moisture in the bottom of the pan after 12 hours of drying.
1089945
Same pans after drying for 24 hours. All moisture is gone.
1089946
This is where I took the DEF crystals from for the test.
1089947
This the Blue DEF I used.
1089948
Here are the crystals in jars for mixing. I put 4 grams of crystals in each jar. The jars were clean and dry.
1089949
I put tap water in the sample on the left first. The tap water was ran slowly and carefully down the side of the jar so as to minimize any mixing. The crystals dissolved instantly and completely as soon as they contacted the water without any agitation. I put 5 ounces of tap water in the jar. On the right side, I poured 5 ounces of DEF carefully down the side of the jar. The crystals didn't dissolve completely immediately, but without agitation about 75% of the crystals dissolved immediately. The wetness in the middle is some spillage I had when pouring. You can see some of the crystals in the picture above on the bottom of the jar.
1089951
I slowly stirred the jar with the DEF 3 strokes CCW and 3 strokes CW. After stirring the crystals are gone.
Also, after I was done with the experiment, I cleaned the pans above outside with a garden hose. I allowed the water from the hose just to trickle into the pans and the crystals dissolved quickly.
So, for me this puts to bed the myth that once the urea crystalizes in the tank it won't go back into solution. No need to worry about that hogwash. But I do believe that is probably best to keep your tank full or nearly full to minimize the overall solution from becoming too strong.
Super Moderator
@Pinkmist ,
Thanks for the experiment. Definitely puts the issue at ease.
Daayyuummm!! I love a good back yard excitement to finally put a little rest on something! Awesome pictures you have all the way though!
(yes it’s supposed to be excitement not experiment) 😂😂
Full def tanks, using good quality def, gives these systems the best fighting chance to work correctly and for the longest time, period. This has been the direction given since the beginning
Now, the longevity and operation of the dosing nozzles and nOX sensors is a different story but I digress.
Great experiment, btw. 👍🏻
Liquid DEF is some chemistry straight from a Harry Potter movie. Potions Class | Harry Potter and the Half-Blood Prince - YouTube
The 'spec' for the DEF is in the whole percentage points.
Its hard to say how many %. Because the sensor itself is frankly not that accurate. The more you deviate from the magical 33% w/w the more likely the sensor will catch you.
Some trucks are using dedicated sensors now which may be more picky. But all our trucks use the crappy old ultrasonic system.
Problem is he used tap water to redissolve the crystals. My experience comes from dealing with dispensing issues, the customer let the tank run dry, we refilled it and expected the DEF to redissolve them in the lines and pump. NOPE, everything needed to be either replaced or scrubbed before it would work.
Super Moderator
2017 GMC Denali 2500HD, 3.5" Rough Country Lift, 305/55R20 Yokohama Geolandar A/T
He used tap water and more DEF. The tap water dissolved the crystals immediately, and the DEF needed a little agitation to dissolve.
The issue, as he pointed out, is that when you dissolve with more DEF, you're going to have a higher urea concentration than what is spec.
I see the benefit from this as being that if you get def crystallization in your tank and lines, you could potentially flush the system with tap water instead of replacing everything. I don't know what that process would look like, but it's probably cheaper than replacing everything.
2021 3500HD GMC Denali
Excellent demonstration. Now I’m curious, there is one thing you missed in your experiment. Heat,
What is the DEF was rapidly heated to simulate the tank heater? Would the elements get caked off with crystals, and would fresh def or the presence of DEF in the tank remove that buildup?
Discussion Starter · #9 · (Edited)
I used tap water in one jar only, and fresh DEF in the other. It took longer for the DEF one because saturation level of fresh DEF..
Also,I mentioned that dried salts would increase the percentage of the solution in the tank causing problems. That is why I suggested keeping the tank topped off was best.
My point was some say that once the salts occur, they won't redissolve. That is BS.
Super Moderator
I didn't use tap water to dissolve. I used it to rinse the pans. In the jars I used fresh DEF.
No, your post shows that in the jar on the left you used tap water, and the jar on the right you used fresh DEF.....
I made an error in my reply. That has been fixed. I got pissed off at darmah59 because his reading comp sucks.
2021 Silverado 2500HD LTZ L5P
I keep an eye on my def tank concentration through my banks idash. my 2021 ltz has a def sensor that knows the current concentration in the tank which should be around 32%. I would assume if that number changes dramatically I should probably take action and drain the tank.
I test my def before I put it in the tank. I figure it's cheaper to buy an idash and a tester than it is to replace a dpf system for a problem that can be avoid by being proactive
1 - 12 of 12 Posts
