1 - 20 of 27 Posts
Im installing the dmaxstore front end stage 3 kit. i already have the right side off and im working on the left. iv used a breaker car and socket, even tryed jumping on it with everything iv got. i dont have the air to run a 3/4 or 1 in impact. any ideas please?? and could it be left handed threads??
i thought the same thing but im trying to avoid that. what if i took a air hammer to it?
Recovering Diesel Addict
Take air hammer to it... won't hurt nothing, if all else fails, and you are replacing hub, use some heat on the nut, like tgreene said, won't take much.
A snipe and a good 3/4" socket set usually works fine.
They are not left handed.
I just took mine off about 20 mins ago... :) came off like a dream because I copper coat everything on my truck lol.
you say you dont have enough air to run a 3/4 or 1 inch gun but do you have enough to run a good 1/2 inch gun? i have never had a problem with them using my 1/2 inch gun and a hub nut socket.
yes sir i do, which it took the right side off just fine. and just tryd the air hammer and the nut dont even budge.
if you got good penetrating lube, spray it and wait til morning?
They come with some high strength thread locker from the factory, a little heat softens the "glue" and you're good to go. If it's been off before it may be a lot easier since it probably didn't get the thread locker.....
Im Superrrrr!
Use heat....It prob has a shit ton of threadlocker on it.
well iv used heat, 1 in impact and 5 ft cheater. how should i go about cutting the SOB off?
Administrator
Take pictures .... I know a LOT of guys looking at this kit.
Discussion Starter · #15 ·
i most deff will. think i could just cut the cv in half?
Administrator
Discussion Starter · #17 ·
I have had a nut that did not want to come off, I am not a fan of using heat, I use a high speed cutting wheel and cut into the nut on three sides, soak it up and use a decent impact and off it comes. If it does not come off just cut three more slices either farther in or out a bit. use the impact when the nut has some heat in it. Works for me! you do need a new nut.
Don't left handed nuts have notches on the outsides of the heads?
No don't cut the CV in half it won't do you any good.
1 - 20 of 27 Posts
