1 - 20 of 47 Posts
If I post this in the wrong place mod's please move..He not really a LLY anymore :rof
LBZ Block (tricked out)
LBZ Crank, flex plate, harmonic bal (use as set, different balance)
LBZ water pump (it's bigger, no overheating here! )
LBZ primary CP3, LBZ secondary
LBZ reluctor wheel with one tooth ground off
SoCal Diesel ported LLY Heads with hardened pushrods and high speed springs
LLY head gaskets, thinnest.
SoCal Diesel LBZ 15:1 ceramic coated pistons
SoCal Diesel keyed LLY "special" cam
Crower rods
Discussion Starter · #2 ·
Casper came alive last night & I have put about 100 miles on Casper since last night. Gotta to love a hubby that let's me play with his new toy :rockin
We hope to get him dialed in for DHRA event in Vegas next week :gearjamin
Looks good. Real good. Are you still using the 5 speed or have you upgraded to the 6 speed?
Thanks :D
We are still using the 5 speed for now. If McRat thinks we need the 6th speed will have MikeL do the upgrade :rockin
Pat let me take Casper to LACR tonight for a few shake out runs.
Best was 11.55 @ 119.60 with a 1.76 60ft time
He is going to work on tuning tomorrow :D
Discussion Starter · #15 ·
Congrats!!!! Was this the same tuning as the 11.77 run?
Thanks
Yes, we wanted to do baselines before changing anything :D
Now it's time for Pat to go to work.
Discussion Starter · #17 ·
Cool......I think this is gonna be one of the 10sec fuel only trucks that we'll see in months to come!!!!!
That is what we are hoping :D But I learned with the vette not to count my chickens before they hatch :cool:
I like the intake :D
Ghettous Maximus is the brand name on that baby! It's industrial exhaust hose, and very sturdy, not like dryer vent. It has thick stainless wire as the coil material, you can nearly stand on it without it collapsing.
Order it through www.mcmaster.com I'll get the PN if anyone is interested.
There is also an electric DHRA air shutoff on the charger, as well as an LBZ intake manifold which flows ~23% better than a LB7 or LLY piece. The electric cutoff needs you to have a lathe to make it at home. I have blueprints for those interested.
Intercooler tubing was a bitch, but held 60 PSI without problem so far, and is tucked in well. It can be made at home with the exception of one piece which had to be cut and beaded with a $140 beading tool from www.summitracing.com
Diesel Addict
congratts....looks great and good luck
1 - 20 of 47 Posts
