Center Console Key Help/ Power Door Lock Issue
Does any one know the least expensive way to get a key made for a center console for my 01 LB7? The dealer wanted almost $80 for a key!!
I'm sure that the lock smith isn't much cheaper. It's key lock cylinder # 035.
I'm also having problems with my power door locks, They work on/off.
The windows and power seats are fine. I checked all fuses, connections and relay's.
All that happens is The relay clicks, sometimes I can move the inside fuse panel around and it works, sometimes it doesn't? Could it be a bad ground somewhere?
Any Idea's?
Any Idea's?
