1 - 14 of 14 Posts
This morning I left for work and the voltmeter was down at ~12 for the first 1/2 mile or so. It finally came up to ~15 or so but it was slow. When I got to work I shut it off and restarted and there was a slight delay but nothing like earlier. Have any of you seen this / is this normal?
Thanks,
The delay in charging after start up is NORMAL. Mine does this and so has every Dmax i've owned.
Its the grid heater, intake air heater, whatever you want to call it. It pulls a TON of juice. It stays on for a while on cold starts to warm the incoming air and help clean up emissions.
Sent from my Droid using the AutoGuide app while not driving...
I have noticed more of a draw on my 2011 as compared to the 2005 I had. Allot more stuff drawing juice on startup.
Its probably due to the intake heater. It really helps clean up the emissions which is why its there. My lmm stays at like 11-12 volts for a good 10-20 seconds in the fall mornings right now. In the winter it stays on longer.
Administrator
Not all trucks had the grid heater, 2005 may not have. I don't recall which years did and which didn't.
Ya all the dmaxes do. The lb7 has a round style and the rest have the square style one.
Administrator
Are you sure? I have read multiple places that LB7 did, LLY did not, LBZ and LMM did, do you have something that says otherwise?
http://www.duramaxforum.com/forum/0...ertrain/88870-removing-air-intake-heater.html
http://www.duramaxforum.com/forum/performance-upgrades/79352-grid-heater-egr-delete.html
http://www.duramaxforum.com/forum/552300-post26.html
I'm trying to find a thread where Scott had said a certain model which I thought was LLY didn't as well.
Ask one to be one
Yep only LBZ and LMM have them oh and LML I am sure but I have yet to get too deep in one of them.
Guess I'm wrong. Not the first time :D
I thought they all had em since the lb7 does and lbz does it seems weird to leave it off the lly.
Administrator
Ironically, it was the first time I was right about something though...
Yeah, that is why I remembered it. I couldn't figure out why LB7 and LBZ had it, but they removed for the LLY.
1 - 14 of 14 Posts
