My Duramax has a check air bag light and display. How do I get ride of it?
Sent from my Pixel 3 using Tapatalk
Have it scanned and get the code. That will tell you most likely where the problem is. Sensors tend to be most problematic, but it could be wiring.
Had to replace the driver side impact sensor on my 14 half ton. The plastic housing cracked and I guess it got water in and corroded. Super easy to replace.
Yeah I had the check airbag on a ‘05 GMC Yukon. There are two sensors behind the front bumper. One was swelled up. Assume water got in and corroded it. They are not expensive so I just replaced both and was all good....
