1 - 8 of 8 Posts
Vendor
Every wished you could use your IOS or Android phone to tune or monitor what your truck is doing?
Ever had a problem with something in your truck and wish a tech could look at it live while it was happening and never step foot in the mechanics or tuners shop?
If so, let me introduce you to the EZLynk AutoAgent.
This is the future of tuning! Currently available for the Ford Superduty's this will be available for 10 - 16 Cummins and 11 - 16 Duramax' soon. This device will allow on the fly changes between tunes with the swipe of your finger. The phone app currently available for the IOS allows you to configure your gauges as you want them.
Plug this device into your truck and fire up the app and bam, your truck will be recognized and tunes applied through the wifi and the cloud. No more waiting on a device to shipped or a tune to be emailed!
Synthetic Motorsports is proud to offer the EZ Lynk. More information to follow when it becomes available for the Duramax. In the meantime if you have any questions, fire away. #EZLynk #Autoagent #Syntheticmotorsports #PPEI #WIFItuning #Cloudtuning #Duramax
Get ahold of @mrmanners @BigOlDog @DirtyMarx for more information
Wow innovative!
Vendor
Check out these 20 Q&A for the EZ Lynk system:
1. What can you tune with the EZLynk AutoAgent?
a. The AutoAgent will first tune the 11-16 Ford Powerstroke with shift on the fly capabilities. (Duramax then Cummins to follow with no ETA) the Duramax will not have shift on the fly tuning. On the Cummins the AutoAgent will unlock the PCM and people will no longer need the Bully Dog.
2. The ordering process doesn't ask for a VIN. I know it recognizes the VIN from your system but how does it know the setup of the truck, say emissions deleted?
a. It sends multiple tunes – customer chooses tunes
3. For trucks that are built beyond a delete, how does the system setup for that? Do we need to provide you more information in the order? Right now it doesn't ask for anything beyond the tuning question.
a. We are going to have another tuning option on there. Such as level 1,2,3 more than likely – haven’t decided yet
4. How do you plan to conduct Ford Beta?
a. No beta – going on full public. If there are any issues with device there is a number to: Tech it” to call.
5. When can we expect an android app?
a. Within 6 months.
6. So once the tunes are downloaded to the app, a connection to the cloud is no longer required right? So a Wi-Fi connection in the driveway is all that is needed OR do you need continuous connectivity to the cloud? I think you told me just to download the tune set.
a. Once tunes are downloaded – cloud is not needed anymore unless customer wants new tuning or wants to send data logs.
7. Will need instructions for data logging and getting them back to you.
a. App has instructions/tutorials in it. We plan on making some videos as well.
8. When do you expect to release beta for Cummins and Duramax?
a. No ETA for cummins and Duramax. Wild guess would be Duramax by end of this year and cummins next year.
9. If you remove the EZLynk does it lock it somehow to that vehicle?
a. If they remove EZLynk they can use it on another with new tune purchase.
10. Does a customer who is currently running H&S or SCT need to return their truck to stock before installing the Auto Agent?
a. It doesn’t matter
11. Can you add universal sensors like EGT probes to the EZLynk?
a. Not yet – but it will in the future.
12. Can I use my IPod or ITouch with the EZLynk AutoAgent?
a. All Apple iOS products will work with the AutoAgent. (iPod and iPad’s with data plans or WIFI work the same as your phone)
13. If my phone battery dies during a flash what happens?
a. If during the flash process your phone dies or you receive a phone call the flash will pause and when your phone turns back on or the phone call end the device will continue flashing. If you unplug the AutoAgent during the flash process it will kill your ECU.
14. How difficult is EZLynk AutoAgent to install?
a. Installing the AutoAgent is as easy as connecting your smart phone to your AutoAgent with a Wi-Fi connection. The AutoAgent will then connect to the EZ LYNK Cloud and it will search for the trucks profile. Once the profile has been found (this process is instant) it will begin flashing. Once flashed you will be able to make selections to the truck about what HP level or if it emissions deleted or emissions present, tire size… etc.
15. Can I use the EZLynk AutoAgent on more than one truck?
a. he Auto Agent can tune truck after truck as long as your purchase another tune for the next truck that you are tuning. It doesn’t have a limit to how many it can tune.
16. What are the hp levels for the Ford tunes?
a. Stock
b. 35HP
c. 50HP
d. 65 HP
e. 100HP
f. 135HP
g. 150HP
h. 200HP
17. Do you require a wired switch to shift on the fly between tunes?
a. No switch is required. You can change tunes by swiping between them on your app.
18. When someone has a bigger turbo, twins, injectors and/or different pumps how does the app recognize that and still provide the right tunes?
19. Will AutoAgent tunes affect Factory exhaust brakes?
a. EZLynk AutoAgent has no affect to factory exhaust brake.
20. Will tuning be available for transmissions?
a. Yes the Ford tuning coming out first will have transmission tuning.
Vendor
Here is a link to our EZ Lynk Auto Agent page in our store. Remember that you can get the device alone and use for diagnostics and gauges. It will use the existing EGT probe in your downpipe or if you have changed downpipes you can move it somewhere else.
EZ Lynk Auto Agent
Talk to us for your delete questions. We can package this up with an exhaust, EGR blocker plate and even a lift pump for an great price.
Let us know if you have any questions.
Vendor
Discussion Starter #7
A little more info from the guys at PPEI:
GM: 2011 – 2016 6.6L Duramax:
o ECM Tuning
o Read & Clear Diagnostics Trouble Codes
o Record Live Data & Playback Data Logs
o Apple iOS & Android Smartphone support
o Cloud Based Tuning Platform
2011 – 2016 LML Duramax LML SOTF Power Levels:
o 30 HP – Optimized Stock
o 60 HP – Tow
o 100 HP – Street
o 150 HP – Race
o 200 HP – Maxx Effort (lift pump recommended)
The AutoAgent connects to the vehicles via the OBDII-port and broadcasts a Wi-Fi access point (AP) which allows a wireless connection to the vehicle using any iOS device (Android support coming soon – will also support the inexpensive Android monitors). By launching the free EZ LYNK application on an iOS device, engine data is seamlessly streamed to the iphone or other smart Apple devices (Android support coming soon). The AutoAgent also has the capability to reflash vehicle system controllers with ECU profiles shared by technicians.
Technicians will quickly learn to appreciate the EZ LYNK Cloud where they can easily manage customers/vehicles and all the data associated with them (datalogs, engine profiles, vehicles information). Transferring engine profiles via USB connection, SD card or e-mail are now a thing of the past as technicians have the capability to share engine profiles with the click of a button to completely eliminate user-error from the equation.
On the other side of things, the end-user can conveniently share datalogs and other vehicle information to any technician with the touch of a finger without even leaving the driver seat. Datalogs can be quickly started and stopped from the main gauge display screen and bookmarks can be added to draw interest to the specific points of a datalog if desired. A graphical web-based datalog viewing solution will soon be incorporated into the EZ LYNK Cloud as well.
A fully customizable user interface allows the end-user to create a gauge interface that suits their particular needs. Technicians can also create default PID configurations that are automatically loaded during a reflash procedure to further assist in the troubleshooting and diagnostic process.
Once you have downloaded the AutoAgent iOS App and created an account please feel free to navigate around the AutoAgent App. To watch a tutorial of the AutoAgent interface click the menu icon in the top left>Settings>View tutorial. There are 6 steps that you can swipe through to check out what EZ LYNK has put together for there soon to be available AutoAgent!
Vendor
Here is a quick video of a Fish Tuning digital Shift on The Fly LML switch.
LML Shift On The Fly
Are you ready for the future of custom tuning? Ready to have Shift On The Fly tuning for your 2011 - 2016 Duramax? Already running PPEI custom tuning on your LML? Get a 100.00 Rebate towards an EZ Lynk Auto Agent.
Get this Fish Tuning Digital Shift On The Fly Switch.
Get your EZ Lynk Auto Agent with PPEI Custom Tuning from Synthetic Motorsports.
Synthetic Motorsports is the largest distributor/retail outlet for PPEI Custom Tuning! Let @DirtyMarx, @BigOlDog or @mrmanners help you with your custom tuning needs today! #Syntheticmotorsports #PPEI #ezlynk #ezlynkautoagent #sotf #lmlshiftonthefly #autoagent
1 - 8 of 8 Posts
