1 - 20 of 33 Posts
Supporting Vendors
Chevrolet Silverado License Plate LEDs
License plate bulbs are used to illuminate the rear license plate on your truck. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
Newer luxury vehicles use LED modules to illuminate the license plate with modern, cool white light. By changing your license plate bulbs to LED, you can easily add this luxury look to your Silverado!
The installation is 100% plug-and-play, just replace your factory bulb. (Installation Video Available)
With low price and easy install, this is one of the best, easiest modifications you can do to improve how your Silverado looks at night.
Brightness:
Diode Dynamics offers several bulb options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
SMD2: Slightly higher brightness than OEM bulbs. (24 lumens)
HP3: Much brighter than OEM bulbs. These are bright! (56 lumens)
HP5: Nearly triple the brightness of stock OEM bulbs! (92 lumens)
Bulb Design
SMD2: Compact design, with two 5050-size Epistar SMD chips, driven at high power for maximum effective brightness. Outputs at 180 degrees.
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your Silverado).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
1999-2013 Silverado License Plate LEDs
2014-2015+ Silverado License Plate LEDs
194 LED Bulb Models
If you have any questions, please don't hesitate to post, PM, Email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Customer Submitted Photo:
Most Known Unknown
here was mine when i first put these in along with new reverse bulbs in the LML
this is an old picture, because i have since then moved to a new place AND installed the exact same lighting setup on the gray gasser :thumb
i have a dark driveway thats a little lengthy, and these help ALOT!
Bulbs from DIODE DYNAMICS :thumb vs Stock :eek:hno
Need to swap a few stock bulbs for LED's: interior dome lighting (on head liner between driver & passenger seat), license plate lights, and all 4 door courtesy lighting. Having trouble finding model #'s for the dome bulbs and the door courtesy lighting.
Supporting Vendors
@Trossi,
Please contact us and we can assist you in finding bulbs for your truck: (314) 205-3033 or email: [email protected]
Thanks!
Nick C.
Pm sent
I just ordered a two sets, and maybe a few other items....haha
any idea when your switchback markers will be back in stock?
Was wondering if you knew when you were going to have the XML2 5000K Pure white fog lights in for a 2016 Silverado 2500? Also, is there any modifications that need to be made or is it plug and play? Thanks.
Supporting Vendors
Discussion Starter #16
We are in the process of updating the listing, but the 2013 uses the same size: Fog Light LEDs for 2007-2013 GMC Sierra 2500 (pair) - Sierra 2500 - GMC - Products By Vehicle
Here's the installation video we put together when the truck was in our studio:
Thanks!
Nick C.
These are the standard smd2 bulbs. I think they are much brighter than stock. I love them!
Yea - late to the party on this one. I'm trying to see what options you have for my ride and am getting "There was a problem while using XMLHTTP:" on your website.
Looking for lighting upgrade options for 2015 GMC 2500.
I'm going to claim that this has been going on since before the 4th...that's why i didn't get to order them with the 20% off...yea...thats the ticket!
Thanks
1 - 20 of 33 Posts
