1 - 12 of 12 Posts
This seems to be my trucks favorite noise. Most noticeable at low speeds like in parking lots. Go to turn onto a street and start to turn and i get a clunk from what sounds like the rh front. Turning to the left seems to set it off the best but usually when i start turn she clunks. Sounds different than the steering shaft rattle unless that starts as a clunk, although i cant really feel it in the wheel.
What the heck could it be i am about to tear into it? Where should i start?
My old truck ate sway arm links for awhile but those seem to be intact however i have not looked to see if the nuts are still on the bottom yet.
Any Guidance?
Thanks
I'M YOUR HUCKLEBERRY
bump for ya, mine has been making some funny noises too....
That could either be the intermediate steering shaft or hub. I am guessing a hub. Jack the front off the ground and try to rock your tires at 12 and 6 oclock...if it moves..there's your fix. My driver's side was clunking when turning..or at least I would get one good clunk.
no not all the time...mine wasnt making noises when it was going bad..just clunking on turns and shaking the front end when going about 55.
they seem to go bad around 60-70,000 miles...its because they are a sealed bearing..not repackable i think.
Got it on the jack to find...
A bad wheel bearing!!! It has play in it when you rock it at the 12 and 6 o'clock positions but it is still quite:confused: Think it is under my power train warranty? I bet not I mean come on there is only a DRIVE SHAFT going thru the center. :cookoo
So what is the best replacement to put in. Anything out there that is serviceable?
I did however find out how heavy the Dmax is seeing as i had to pound my jack stands out of the asphalt once i was done!!
I have the same klunking noise. Seems like its coming from steering components.
Get the timken one from dmaxstore.com. I believe he has the best deal out there and it is lifetime warranty.
If the wheel bearings check out fine: I had a clunk that turned out being the Drive Shaft's yoke in the transfer case. First symptom was a clunk when you turned to the left at slow speed.
Probably from the intermediate steering shaft...pretty common. I just changed mine for the second time in 67,000 miles. Mine was rattling pretty good....the first one was changed for clunking when turning.
1 - 12 of 12 Posts
