ok so i did the led write up with the 1/2 watt 33 ohm resitors and 360 5mm red leds and i pluged them in and did everything its worked for about 5 mins then i seen a puff of smoke some from behind the dash i pulled the cluster and seen that all the lights resistors had eather burned or the soder connections came apart. so what the hell did i do wrong? i followed the write up to the tee and made sure all my soders were good were the resistors wrong?:help:help:help:help
Banned
Man it could be anything. Its gonna be hard to tell without looking at it. What will you have to do to fix it?
i figured it out. i used the wrong resistors now its working fine im gonna post pics in the write up
