1 - 7 of 7 Posts
i know the codes say injector circuit open, but what does that mean? also code p1261 come up it is manufacturer fuel metering. thanks for any help
Please fill out your signature-- [top "User CP'] We don't know what you drive-!
There are several problems with each series engine-- We can help!
4.5/05 [LLY] had injector connector problems-- a quick stab with a sharp ice pick would make it like new. Free!
Someone will chime in here-- lots of guys have LB7 engines.
Have you had a recent injector work-? a loose connector or a shorted injector wire will cause problems.
Good Luck :)
yea just replaced the injectors a week ago and been having problems ever sence. first it was air in the system and found a pin hole in the fuel line fixed that, then found a pinched o-ring on one of the injectors. when we got it back together it idled real smooth but going down the road the motor was just noisier than before. tonight i unplugged the programmer(banks 6 gun) and drove it. seem to run and shift smoother but the more i drove it the noisier it got(or atleast it seems that way). well on the way home i put it to the floor and it ran up and didn't shift for a few seconds and the went into limp mode with the service engine soon light on. check the codes and that is what come up. when i pulled up to the house it sounded like it was only running on about 4 cylinders. my question is could it be the connections still? thanks
On the LLY engine-- when a injector looses contact, it will go into "Limp" and and set codes. Just like you have-- The Power control module will sense the problem and include all injectors in group A, or group B, what ever the bad injector is on. It will be on 4 cylinders -- runs-- although not very well, and noisy. The RPM will be limited to 2,000 RPM.
Your problem might be a loose connection, or a bad injector. It will have to go back to the shop that did the injectors. A injector balance test may locate the problem.
Good Luck.
1 - 7 of 7 Posts
