I have a 2001 Duramax that has is on it's 3rd set of injectors with 120K Mi
Last summer it blew a head gasket. Took it to the dealer and it took 3.5 weeks to get it repaired
Got the truck back and no accelerator power. They replaced the Torque Converter
That did not fix the problem. Turned out they had to replace the injectors again. That seemd to work
Now under load while towing my 31ft trailer when accelerating reaching 55-60MPH when gear shifts I lose power. Zero pedal. I pull over and shut it down. Wait a minute or two. Start it and runs fine. Once I hit between 55-60MPH and shifts it happens again.
I have had this same problem in the past and replaced the injectors then and it was fixed
Not sure if all of the injectors were replaced
Is there a test to see if the injectors are working properly?
Also the code that is pulled is P0234 Turbocharger Wastegate Solenoid A Malfunction
Any ideas. My GM/Chev dealer lost their Diesel Mechanic. Not they he was very good anyway
