On way in to work on Interstate, check engine light came on. Gages looked normal and no out of ordinary engine sounds or performance that could tell. Stopped at dealer after work and code P2C7A was set. The message that received is "An issue with the emissions system has been detected. Please service your vehicle within 7 days.". Does this mean that after 7 days the truck will not run? This sounds similar to the consequences about running low or out of DEF. The code is "NOx Catalyst Efficiency Below Threshold Bank 1 Catalyst 2". Has anyone received this code and were replacement parts needed or is this a "software" glitch? With the stated supply problems the truck might be at dealer for some time in case there are not replacements there.
