2013 Chevy Silverado 3500 dually
6.6 lml
Allison 1000 auto trans
Everything is stock except having a CM flatbed installed 1½ years ago.
I was driving Saturday, kinda crappy rainy day, and suddenly my truck feels like it lost power. My first thought was fuel filter because I know I'm over due to change it. Check engine light comes on so I pull off and scan it. I notice that it's not accelerating the same, then when I went to put it in park in clunked HARD. Scanner pulled a generic U0101 code-TCM lost communication. Cleared codes, start the truck up and notice no indicator line on the PRNDL. Shift into reverse, clunks hard, shift into drive and it clunks hard again. Start limping it the 30 miles home and am limited to 3rd gear (I think, maybe 2nd). Truck starts dinging and ABS and Brake light come on. Scanned again when I got home, still U0101 code. Cleared it, check engine light goes out, but no other change. Said screw it and went to bed. Next morning, start the truck up, no codes, no lights. Drive it down the road, shift indicator light disappears, abs and brake light come back on. Drove it in Limp mode to the parts store for them to check batteries and scan it for me. Had one weak battery, decided to go ahead and replace both. Their scanner showed the same U0101 code and a C0055 code (ABS /Rear speed sensor.) Noticed limping back home that the speedometer was being erratic and would jump or drop 5-10mph with no change in acceleration. Changed the VSS on the transfer case, cleaned the ground on the frame under the driver's side, disconnected and cleaned wiring harnesses, checked all fuses, pulled TCM and checked harness for power, checked as best I could for loose or damaged wiring. Everything checks out, but it's still doing the same thing. I disconnected the batteries for 24 hours and tried the TCM reset procedure, still nothing. Check engine light will go out, then come back on as soon as you drive or idle for a few minutes. I'm at a loss, please help! I'm hoping it's not the TCM, because nobody has one.
6.6 lml
