1 - 9 of 9 Posts
Hello everyone. Back again with a question about my wife’s truck.
I’m having a real problem with rodents chewing my wires. Here’s the most recent. Can someone ID the component where the wires are attached? It doesn’t look like the wire are completely chewed through.
And what about this thing that looks like a temperature probe?
This is the third time. I bought two rid-a-rat units, one that connected to the battery and a second one that operates on AAs. The rodent chewed through the wires on the first one. So much for a deterrent.
Thanks in advance.
First one in your inlet nox sensor.
Second one is one of the intake temp sensors.
2007 GMC Sierra LBZ
X2 to the above
Peppermint spray or mint plants (they're invasive so keep an eye on them) around the shop/garage/parking area. Will keep all kinds of rodents and bugs away.
Thank you for the information. Only two strands were still intact in the orange wire so I spliced in a three inch piece Now I’ll research what those two things actually do.
I found an intake temperature probe for $40. Replacement looks pretty straight forward. One end clicks into a receptacle and the probe screws into the engine. I can’t screw this up, can I?
John
2016 Chevrolet Silverado Duramax
Moth balls inside engine compartment is what I use. Never had a problem with my car sitting in my driveway for a year before I repaired the transmission.
I don’t know which one to order. Picture in the first post. Thanks for any and all help. John
Part Number: 129804-05732200
Brand: Standard Motor Products
Notes: Engine Intake Manifold Temperature Sensor -- On Throttle Body
Part Number: 129804-05732201
Notes: Engine Intake Manifold Temperature Sensor -- Between Intercooler and Throttle Body
The best way I know of to choose the correct part # is to use your VIN# on a GM-based website instead of year, make,model. You will get the correct GM/ACDelco part number that way. Once you have that, you can use it to shop for the part price, delivery time, warranty,etc that you are comfortable with. Many, most, of the GM based web sites have pictures of the parts. If not, use the listed part number and go to Google Images and use the images there to find the part that looks like the one you want.
Reactions: jbell1033
1 - 9 of 9 Posts
