I'm a new member and have searched the forums and found some very helpful info so far. Recently I noticed I was losing a large amount of coolant, but couldn't find a leak anywhere. After further investigation I found that I have water in my oil. When I pulled the dipstick the oil is a creamy grey and very watery. Most things I've found have mentioned that it's usually a head gasket leak, but I also read something about the upper radiator hose being hard. So far the radiator hose is always soft and when I loosen the resevoir cap it doesn't seem to have much pressure behind it even when the engine is hot. Is there anything else that could cause coolant in the oil? I am trying to find a reputable diesel shop in the Houston area, but would like to have an idea what I'm walking into so I don't get screwed by the mechanic.
BTW, Truck is 2003 LB7 with 240k miles. I have already replaced the injectors 3 times under warranty.
Thanks,
-Brandon
Thanks,
-Brandon
