I had lots of coolant in oil so I drained oil, filled back up with oil and now that my coolant is low no coolant in tank I'm not getting any more coolant in oil so how is coolant getting in oil when tank is full? Need help
Discussion Starter · #2 ·
I don't want too do HG if that's not the problem, water pump is leaking out weep hole. Is it possible the water pump can cause coolant to fill engine?
Not an expert but I am pretty sure its not possible for the water pump to allow water to enter the engine oil without there being a crack in the block.
The water pump is gear driven off the crank so I think it would be possible.
OK thxs, its got 295000 on it and I'm not sure if head gaskets have been done before so all do new HG with studs. Anything else I should do while in there?
