Hey folks, as the title suggests, I’ve got a coolant leak going on. When I pressurize it with my tester, it shows up as a slow drip off of the oil filter housing on the drivers side of the truck. It is coming from somewhere above that though, but I can’t seem to get a good enough look to find where. Only found this because I had a cracked quick connect at the heater core on the firewall, so after replacing those I pressure tested to make sure there were no leaks after the fix. The heater hoses were fine, but this other leak showed up.
Any suggestions on where it could be coming from? I am planning on taking things apart tomorrow to get to the turbo cooling lines to see what condition they are in. But from searching old threads, it seems when those leak it is a large leak rather than slow dripping. I suppose at over 330k miles it could be a head gasket, but I am certainly hoping not. Thanks in advance for any further suggestions on where to look.
