Hey guys, I have a 2006 Silverado with the LBZ. I have been trying to find this coolant leak for the past couple weeks when I have the time. It trickles down the passenger side and onto the oil pan, then drains off the edge. I thought it was that 1x4 inch coolant block off plate ive seen being discussed before, but I was able to snake my phone up behind the downpipe and saw that it isn't that plate, its just to the right of it, and above. (Attached pictures show this.) It doesn't seem to leak a drop when it is warm, but overnight if I come out I see it drip a few times a minute, it empties my surge tank pretty much overnight. Ive had all the coolant drained previously so could I not be adding coolant properly and causing air to be trapped in the system that it forces coolant out of a weephole? Could it be a freeze plug? I have no idea where to look, its looking like im going to have to pull the egr and/or turbo to get to whatever is leaking. I have no signs of a headgasket leak, no excess pressure, no coolant in my oil, no oil in my coolant, no pressure after truck is cold. Any ideas what to do? Please ask me questions about it so i can help whoever is able to pinpoint where i should look. I haven't had the egr deleted so maybe it is leaking? I can't see anything from up top. Is there a coolant line that goes under anything that I can easily get to on the passenger side? Since it leaks very little when cold should I assume its a gasket and try some kseal or bars? Any insight on this would be helpful. Thanks for reading. (If anyone needs me to take more pictures just ask.)
