1 - 2 of 2 Posts
Well I posted this problem in my LLY section but have not gotten a reply so I thought I'd try here sense I think the pump is the same.
I think my water pump is leaking but its not from the weep hole. It is leaking above the hole. There is a bolt boss for the water pump above the hole. The coolant is dripping from there or off there coming from above the boss. I cant see past there from underneath. Is there anything above that area it can leak from. It's a small leak. Started last week one day then stopped then showed up again.
It looks like it is leaking from the mating surface of the pump housing to the block I think.
It is not dripping from above this are. I can squeeze my finger above there and feel nothing.
Please help me out here.
Thanks
two options at this point
I would either keep an eye on coolant resivor and run it till it stops working
or
Replace it and drive another 100K miles again.
1 - 2 of 2 Posts
