2017 high country duramax, 64k on the clock. I have a few issues going in and could use the forum for some help.
My horn was intermittent when locking the truck with the fob, over a few weeks it would function/ then not. Finally it completely failed, also when pressing the horn in the truck its not functional. I need to understand if this is common, where the horns are located in my truck and what the common repair is for this situation. I did check my fuse and it is good.
Heated/ cooled seats, they work good when i manually turn then on, according to my dash computer heat and cool function is turned on with remote start.
But They do not turn on when remote started i have tested in 100+ and today at 26 degrees. is this a common issue and is there a repair, its getting cold here in new england, it was hot all summer
Maybe a little help on your horn:
Horns Malfunction
Diagnostic Instructions
  • Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure.
  • Review Strategy Based Diagnosis for an overview of the diagnostic approach.
  • Diagnostic Procedure Instructions provides an overview of each diagnostic category.
Diagnostic Fault Information
Circuit/System Description
Battery positive voltage is applied at all times to the horn relay coil and horn relay switch. Pressing the horn switch applies ground to the horn relay control circuit. The body control module (BCM) also may apply ground to the horn relay control circuit. When the horn relay control circuit is grounded, the horn relay is energized and battery positive voltage is applied to the horn via the horn control circuit. The horn will sound as long as ground is applied to the horn relay control circuit.
Diagnostic Aids
If diagnosing a Horn - Poor Tone condition, inspect the following:
  • Debris or water in the horn assembly.
  • Proper horn mounting hardware torque. Refer to Fastener Tightening Specifications.
  • Debris in the joint where the horns attach to the vehicle.
Circuit/System Verification
  1. Ignition OFF, connect a test lamp between the HORN fuse test point and ground.
  2. Press and release the horn switch. The test lamp should turn ON and OFF when changing between the commanded states.
    • If the test lamp does not illuminate or remains illuminated at all times, refer to Horn Switch Circuit Test.
  1. Ignition ON, command the horn ON and OFF with a scan tool. The test lamp should turn ON and OFF when changing between the commanded states.
    • If the test lamp does not illuminate, test the control circuit terminal 18 at the BCM for a short to voltage or an open/high resistance. If the circuit tests normal, replace the BCM.
  1. Connect a 10A fused jumper wire between the HORN fused test point and B+. The horns should sound and emit a clear and even tone.
    • If the horn does not sound, refer to Horn Circuit Test.
    • If the sound emitted is not clear and even, refer to Horn - Poor Tone.
Circuit/System Testing
  1. Ignition OFF, disconnect the harness connector at the horn switch.
  2. Test for less than 1 ohm between the ground circuit terminal B and ground.
    • If greater than the specified range, test the ground circuit for and open/high resistance.
  1. Connect the harness connector at the horn switch.
  2. Disconnect the X4 harness connector at the underhood fuse block.
  3. Connect a test lamp between B+ and the control circuit terminal G1.
  4. Press and release the horn switch. The test lamp should turn ON and OFF when changing between the commanded states.
    • If the test lamp is always ON, test the control circuit for a short to ground or a sticking horn switch. If the circuit tests normal, replace the BCM.
    • If the test lamp is always OFF, test the control circuit for a short to voltage, an open high resistance, or a horn switch which is not closing.
  1. Ignition OFF, connect the harness connector at the underhood fuse block. Disconnect the harness connector at the appropriate horn.
  2. Verify that a test lamp does not illuminate between the control circuit terminal B and ground.
    • If the test lamp illuminates, test the control circuit for a short to voltage. If the circuit tests normal, replace the underhood fuse block.
  1. If all circuits test normal, replace the underhood fuse block.
Horn Circuit Test
  1. Ignition OFF, disconnect the harness connector at the appropriate horn.
  2. Test for less than 1 ohm between the ground circuit terminal A and ground.
  1. Connect a test lamp between the control circuit terminal B and ground.
    • If the test lamp is always ON, test the control circuit for a short to voltage. If the circuit tests normal, replace the underhood fuse block.
    • If the test lamp is always OFF and the circuit fuse is good, test the control circuit for an open/high resistance. If the circuit tests normal, replace the underhood fuse block.
    • If the test lamp is always OFF and the circuit fuse is open, test the control circuit for a short to ground. If the circuit tests normal, test or replace the horn.
  1. If all circuit test normal, test or replace the horn.
The heated seats is that they won't feel warn to the touch after remote start.
The indicator lights do not come on during remote start -- even if the seat is heating or ventilating (they are not cooled, only ventilated; common misunderstanding).
When the truck is turned on with the key, the seats will be shut off, and need to be manually reactivated.
