1 - 12 of 12 Posts
Hi checked my tranny for oil today and half of the dipstick tube came up with the dipstick. Is this easy to change?:help
I had the same issue, infact mine is still broken. Just get some hose and hose clamps and put it back together. Put foil inbetween the turbo dp and hose so it doesnt melt
Its just a worktruck
It is easy to change. I've never done it, but I think its only a few bolts.
i found it to be difficult, but only because it was too hard to put the bottom part back in the tranny with the rubber seal that is on there... I actually got frustrated and messed the seal up. I would definitely just use hose clamps or something unless you are losing fluid...
It's pretty far up so no leak, hose clamp and hose it is then. Thnx guys :drink
let me know if you need some pictures of how i did mine
ill get some up tomorrow for you, it is snowing here as of now
DuramaxForum Veteran
The dipstick tube takes some finessing to change. There are two nuts that you will need to remove with a 13mm. Then just slide the tube straight up and finesse it until you get it out. Having it in the truck like it is in your case makes it tough, but it can be done just be patient with it.
If you need a dipstick tube check around, theres probably plenty of people with one laying around, especially those who switched to Mike L.s drivers side dipstick tube.
does that rubber seal go completely down into the hole in the transmission,or is there suppose to be part of it sticking out ,i just tried to put my new dipstick tube in my 08 and it was a major PITA,not enough room to raise it up enough ,i got it in but the seal is not sitting right
This happened to me too. I took it out and welded it. It is a bitch to get the rubber seal back in but it needs to be in there all the way or it can leak or get dirt in your tranny fluid. The easiest way to get the dipstick tube back in there without fighting it too much was to loosen the front body mounts and jack the body up just enough to make some room in there. hope this helps.
i didnt pay attention when we took it out,but i think my seal has a shoulder on it that sits on top of the transmission,will loosen up the cab bolts and try that ,that will work because i only needed a couple more inches
1 - 12 of 12 Posts
