Need help badly, I'll try to update/ comment when I can but.... 08 lmm just had engine rebuilt, deleted, 10mm stroker, 60 overs, fass 150, cranks but wont start. No cel. Fuel pressure while cranking is 7 to 14 kpsi desired is 7, fresh fuel is getting to the top of injectors, I have tried ether no my happiest decision but no choice not proud, hardly runs on that dies instantly.wtf if I remember more I'll comment it plz help, grounds are on and rings are on cam and crank I switched out cam and crank sensors again no change
Did
you ever figure this out? I’m having the same type of issue with my 7.5
More detail about your particular problem would be helpful. Here are a few things for you to check: cam sensor signal, crank sensor signal, the wiring of the mega fuse block - reports made that if improperly wired, truck will not start. Make sure all of your sensors are plugged into the correct place on the harness. Check your ECM connectors to be sure they are clean, no bent pins, no corrosion, etc. Are you getting injector pulses? Have you looked in your fuse box to see if any blown fuses?
